Old 03-28-2014, 02:02 PM   #1
rantiquecar
Default a.transmissions
does the shifting forks or gears hold the 2nd gear in place
rantiquecar is offline   Reply With Quote
Old 03-28-2014, 02:30 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: a.transmissions
The forks do and welcome to the barn.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-28-2014, 03:33 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
If the gear is too loose on the shaft, or bearings worn, or the flywheel housing not correctly dialed in, the gear can "walk" out of engagement.
Old 03-28-2014, 04:20 PM   #4
Bob/Kansas City
Bob/Kansas City's Avatar
If it's popping out of gear it may also be due to worn shift forks and all the wear parts in the shift tower.
Bob/Kansas City is offline   Reply With Quote
Old 03-28-2014, 05:27 PM   #5
James Rogers
James Rogers's Avatar
Where are you in Swannanoa, I live in Leicester.
James Rogers is offline   Reply With Quote
