Old 02-28-2014, 11:10 PM   #1
marc silva
marc silva's Avatar
Default PROS and CONS of a high compression head
I am finally starting the re-build of an engine. Do I put a high compression head on or not? Is it really harder on the lower end? I drive it like a wuss anyway but I want it to "go" when I step on the gas if I need to. Opinions please. Thanks for all your wisdom as usual.
Marc
marc silva is offline   Reply With Quote
Old 02-28-2014, 11:19 PM   #2
tpowel2
Default Re: PROS and CONS of a high compression head
Good question, I would like to know the same thing.
tpowel2 is offline   Reply With Quote
Old 02-28-2014, 11:28 PM   #3
colin1928
colin1928's Avatar
Hi Compression Head do make more Horse Power
Every Horse power made in combustion chamber is transferred through the piston then the con rod then crankshaft
so if you go from 40 hp to 60 hp you add 50% Load and wear to these parts
colin1928 is offline   Reply With Quote
Old 02-28-2014, 11:30 PM   #4
freak
freak's Avatar
That said, I have one and it's been running fine for 10's of years.
freak is offline   Reply With Quote
Old 02-28-2014, 11:38 PM   #5
TerryH
TerryH's Avatar
Most high compression heads do not add 20 hp; using Snyders 5.5 or 6.0 will probably net you around 10 more hp. As for extra wear and tear on the engine, yes if you drive hard and push it all the time, and aren't careful with timing and spark advance, you can do some damage. Many, many of our local club members have them, and they are probably the single most effective way to give your A a significant power boost without compromising the car. I have a Town Sedan, which is one of the heavier Model A's, and it certainly helped.
Terry
TerryH is offline   Reply With Quote
Old 03-01-2014, 12:01 AM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
They are a great addition. They don't do a good engine any harm. However owners ARE more likely to cause harm primarily due to improper use of timing advance. The low compression on the stock engine is very forgiving of misuse. The higher the compression, the more critical the proper use of timing becomes.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 02-28-2014, 11:54 PM   #7
Gary WA
Gary WA's Avatar
What is so different with the timing and spark advance as with a stock head vs high comp head. Is the timing set different with HCH? thanks. Just finished stock eng today with High Comp Head. Ready to fire up tomorrow. What changes should I make prior to starting?
www.whidbeymodelaclub.com
Old 02-28-2014, 11:57 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
HC heads don't need as much advance as a general rule.
Old 02-28-2014, 11:56 PM   #9
Mike V. Florida
You need to relearn the sweet spot for running the engine.
you should run cooler with better gas mileage.
I know of or read that anyone has said "Damn, I wish I left the original head on the engine."
The only problems I have ever heard of come from those that refuse to follow the instructions that come with the head to the letter.
Old 02-28-2014, 11:58 PM   #10
tbirdtbird
let us know how you make out
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-01-2014, 12:03 AM   #11
Pete
Originally Posted by tbirdtbird View Post
babbitt can withstand to 7:1 compression
Would you believe 10 to 1 turning 4800 on mile dirt tracks.
Ed Winfield did it many times. He was almost unbeatable.
Old 03-01-2014, 02:05 AM   #12
gwhite
gwhite's Avatar
Citation, please?
gwhite is offline   Reply With Quote
Old 03-01-2014, 12:00 AM   #13
H. L. Chauvin
Hi marc,
Humble & serious response for you to maybe try:
A. If you presently drive a 1939 pick up & you want to know how it feels to drive a 2014 V-6 SUV, you could read & ask questions how it feels to drive this SUV for 10,000 years & never know for sure.
B. However, if you find somebody with a 2014 SUV that would let you try it, you could save 9,999 years plus 364-7/8 days of reading & asking questions -- not counting a leap years!
C. So, if you could possibly find a Model A owner in your area with a high compression head installed, you could actually "feel" the actual difference to decide if it fits your above mentioned term "Go".
D. In my opinion, your term "Go" will translate into your wanting a higher compression head in any language, foreign or domestic.
Just one opinion on how to "feel" the difference & get your project going.
H. L. Chauvin is offline   Reply With Quote
Old 03-01-2014, 12:29 AM   #14
colin1928
colin1928's Avatar
Very true Pete but Ed like you Stripped down his engines after almost every event
Old 03-01-2014, 01:26 AM   #15
montanafordman
montanafordman's Avatar
I can think of one downside - with a high compression head (and also other common mods like lightened flywheel, b carb etc) you wont be winning the slow driving car games like you would otherwise.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 03-01-2014, 02:53 AM   #16
PC/SR
gwhite: Weiand 7:1 head, carbs, cam, more speed stuff, no pressure oil except center main, babbitt bearings no problems. Personal redline is 4000 RPM. The limitation of the stock Model A babbitt engine is not compression but RPM.
Put on the HC head and enjoy. You will learn to use the timing lever as never before, and become a better driver because of it. Set initial timing in the normal manner. Play with timing to find your sweet spot. Advance and retard as you drive and learn how the engine responds. The engine is more responsive to timing adjustments. Half advance at full throttle for starters, more at cruise, full retard descending hills, for example. As you get used to using the timing you will start to keep your fingers on the lever and adjust it as you drive. It becomes kind of fun and part of the Model A experience.
PC/SR is offline   Reply With Quote
Old 03-01-2014, 03:24 AM   #17
mleder
PC/SR : With my A stuck in the garage till this hard winter ends I can't try out your suggestions right now however I would like a little further explanation on the full retard for descending hills. Are we talking mountain country hills ? regular rolling hills ? and what will I notice hear or feel by using full retard? Thanks, waiting for winter to end in Minnesota to end.
mleder is offline   Reply With Quote
Old 03-01-2014, 06:45 AM   #18
Pat Martone
Pat Martone's Avatar
Maybe it is me, but I've not heard about many blown head gaskets from people using a stock head, but I have heard of lots of blown head gaskets from people using HC heads. (BTW - I'm using a Snyder 5.5 head.)
Also, I would like to learn more about the advantages of using a full spark retard when descending hills. I was thinking that with the wheels trying to speed up the engine (engine braking), you would want to keep the spark advanced. I welcome an explanation. Thanks.
Pat Martone is offline   Reply With Quote
Old 03-01-2014, 12:12 PM   #19
gwhite
gwhite's Avatar
I agree completely, just wanted to see where tbirdtbird came up with 7:1 as being the upper limit. IIRC, diesel engines used babbitt for many years with much higher compression ratios...
Old 03-01-2014, 04:25 PM   #20
colin1928
colin1928's Avatar
Diesel Babbitt is a different mix to A Model Babbitt
it can and has been use in cars
may be 1 of the Babbitt guys can explain the differnce
