I am getting ready to rebuild my engine and will be lightening my flywheel due to the counter balanced crank I will be installing. My question is what do you guys recommend for a pressure plate and clutch? I did do some searching through the old threads and saw many people are lightening their flywheels anywhere from 12-28 pounds but did not find anything on what people are using outside of a v8 set up. (which I am unsure what exactly the v8 set up is, a 30's v8?) Just looking for the best options and ease of availability. Thanks for your help!
Most time the V8 pressure plate is the one Ford used from 1932 till 1948 on all the V8 engines. This plate works great with the original Model A clutch disk and throwout bearing. This is the most commonly used plate for lightened setups, it's what I use.
http://www.model-a-ford-4bangers.com/ |
