Old 01-19-2014, 10:05 PM   #1
31Abone
31Abone's Avatar
Default spark problem stock distributor 30 CCPU
running police head ..number 3 and 4 have strong spark number 2 is so so but number 1 is almost not enough to fire plug ..I have tried a different cap with same result also swapped plugs...whats going on here? SC
31Abone is offline   Reply With Quote
Old 01-19-2014, 10:08 PM   #2
Drive Shaft Dave
Default Re: spark problem stock distributor 30 CCPU
Check point gap should be .020
Drive Shaft Dave is offline   Reply With Quote
Old 01-19-2014, 10:25 PM   #3
29er
29er's Avatar
Also check the air gap between the tip of the rotor and EACH of the four pins inside the distributor body. Perhaps the gap on #1 and #2 is too great. The gap when using a standard head should be about 0.025, but you may want to experiment by widening that. My head is 6:1 and I find a gap of 0.030 works very well. Some people use an even greater gap.
29er is offline   Reply With Quote
Old 01-19-2014, 10:11 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Check the distributor bushings for wear. If the shaft can move sideways it will upset the points opening and spark timing.
Old 01-19-2014, 10:26 PM   #5
Charlie Stephens
How about a import cap with shorts?
Charlie Stephens
