Old 09-26-2013, 02:33 PM   #1
HELENT
HELENT's Avatar
Default Why does it shock me??
Original 1946 Ford steering column, when I blow the horn with my arm in the window it shocks the crap out of me. I have checked all grounds.
HELENT is offline   Reply With Quote
Old 09-26-2013, 02:42 PM   #2
Mike51Merc
Mike51Merc's Avatar
Default Re: Why does it shock me??
This has been discussed before so maybe you can find the thread with a search. A popular theory is that the collapsing magnetic field in the horn causes a reverse voltage spike that may be as high as 100 volts. I'm not kidding.
Mike51Merc is offline   Reply With Quote
Old 09-26-2013, 02:46 PM   #3
zzlegend
zzlegend's Avatar
LOL,,,,,Sorry,,,,,I just fell out of my chair.
zzlegend is offline   Reply With Quote
Old 09-26-2013, 02:46 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Almost sounds like the steering column/gearbox is not SUFFICIENTLY grounded to the chassis. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-26-2013, 03:03 PM   #5
Bruce Lancaster
It has to be something inductive happening in the coil inside the horn relay, as 6 or 12 isn't going to do this.
When it happened to me after I rewired my '48...the shock was enough to lift me out of the seat...I had to swap two of the three wires on the relay to the other terminals and that did the job.
I can't say that I really understand the problem, but that was the cure. This was with the car's original relay and wiring following the book...aside from my having gotten the two smaller wires on the wrong terminals!
Old 09-26-2013, 03:35 PM   #6
Mike51Merc
Mike51Merc's Avatar
Bruce jogged my memory, it was the induction from the relay not the horns. Energizing the relay coil causes a magnetic induction backlash when the coil power is shut off. Just like an ignition coil works.
I know it sounds hokey, but it is theoretically sound. After all, 6 or 12 volts isn't enough to shock you through your skin.
See if it shocks you when the horn is blowing, or instantly as you release the horn button.
Or get somebody to hold it for you, just like when you want to test a sparkplug wire for spark.
Old 09-26-2013, 03:58 PM   #7
ken ct
That exact thing used to happen on my father's 49 Cheby once in a while dont remember how he had it fixed.He was not car minded LOL ken ct.
ken ct is offline   Reply With Quote
Old 09-26-2013, 04:31 PM   #8
Willit Stop
Willit Stop's Avatar
It must be a later Ford "open window warning system". My '36 doesn't have that feature. Just kidding,hope you find the problem.
Willit Stop is offline   Reply With Quote
Old 09-26-2013, 04:31 PM   #9
32phil
Had a 48 coupe(nice car all totally redone) that did that too. I went to the Doctor, I told him when I do that it hurts...he said..... don't do that and it won't hurt anymore. Anyway...I never did find out why that car did that either. It was a killer to start too. I finally sold it a few years ago out of frustration. It wouldn't start the day I sold it and when I finally got it going it shocked me! Glad that POS is gone.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 09-26-2013, 04:46 PM   #10
Carbroke
Put a diode across the inductive load such that it is reverse biased when energized. When you open the horn switch, the diode will dump the induced voltage back across the inductive load, saving you a shocking experience.
Carbroke is offline   Reply With Quote
Old 09-26-2013, 04:48 PM   #11
ford3
i believe the horn relay is the problem, either missing, by passed or its wired wrong, the relay should stop any elecricty from backing up from the horn windings to you
ford3 is offline   Reply With Quote
Old 09-26-2013, 06:44 PM   #12
Gary in La.
Gary in La.'s Avatar
My '46 did the same thing some years ago. I cured it by re-establishing good grounds in the system and with the horn mount bracket to inner fender shield. never did it after that.
Gary in La. is offline   Reply With Quote
Old 09-26-2013, 06:55 PM   #13
rotorwrench
rotorwrench's Avatar
I use what is called a Transorb (very much like a diode) on all the relays of one brand of helicopter I work on. The manufacturer's service bulletin explained it as transient voltage supression. The helicopters use 24-volt systems so it could be a shock sometimes but they were more worried about the high dollar avionics getting damaged than anything else.
Old 09-27-2013, 10:45 AM   #14
Bruce Lancaster
On mine, the car had its original relay and with its original (disintegrating) wiring it worked fine with no shocking. I rewired the car, following original diagrams, with modern wire (back then the only other choice was NOS, and all I found was too brittle to be trusted) and horn worked fine but would lift me out of my seat with a shock. I swapped the wires...I think I followed all the wires and figured out the wires were reversed, changed them, and that solved the problem.
Old 09-27-2013, 11:07 AM   #15
Mike51Merc
Mike51Merc's Avatar
Does anyone know whether a capacitor can be used as a buffer? Or would the capacitor just hold the charge until the next opportunity of discharging?
Old 09-27-2013, 02:01 PM   #16
Ross6860
You use a diode.
We do this on all our control panel relays.
Ross6860 is offline   Reply With Quote
Old 09-27-2013, 11:18 AM   #17
Vic Piano
Vic Piano's Avatar
This is a more common problem than I imagined... the '47 LC (we've been playing with) also had the shocking horn problem. I say "had" because I disconnected the hot lead from the horn relay. I thought it might be a problem with the horn button, spring, etc. as the steering wheel had been previously removed (for what reason I don't know,yet) and replaced in the wrong position. Another electrical problem to be ironed out with this car...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-27-2013, 11:29 AM   #18
rotorwrench
The Varistors we use are the ZA series from Littlefuse. The V47ZA7 that we use would be overkill at 30-volts DC but a V18ZA type would work for the 6 to 8-volt systems. A 10mm disk size should do the trick. These are like two Zener diodes put back to back in the way they work. They are wired in between the power coil terminals of any solenoid type that you can attach them to. We crimp ring terminals on for the big relays & solenoids and solder the little relays used for intercomm systems
Old 09-28-2013, 01:06 AM   #19
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Some refg equipment has a quencharc a cross the line solenoid valve. It's a combo capacitor/resistor. This absorbs the collapsing wave, which will sometimes trip the GFI. It's a drag to find your reefer has been off all nite!!
Old 09-28-2013, 01:41 AM   #20
pineapple
pineapple's Avatar
Ha Ha, I thought this nonsense only happened to me. I completely re-wired my 51 f1 (12 volt negative ground). Everything works just Jake, except when I honk the horn with my arm out the window..Big shock..I figured a ground reversal problem that I was to live with...I will reverse the wires like Bruce said..
Matt.
pineapple is offline   Reply With Quote
