Old 04-08-2013, 12:18 PM   #1
Lebowski
Lebowski's Avatar
Default Where EXACTLY is the serial number on the frame?
I went to get plates for the Model A today and they wouldn't accept the number on the engine. They said it has to be on the body or the frame. After I got home I drove the left two wheels up on ramps and looked around on the left (driver's side) frame rail and couldn't find any numbers. I've seen some pics of it being on the top of the frame so how is anyone supposed to see it there? Is there anywhere else I can look? Someone suggested in another thread that the body has to be removed from the frame so please don't suggest that because I'll sell it before I do that. Where EXACTLY is the number on the frame? Thanks in advance....
1952 Crestline Victoria/flathead/Fordomatic
1972 F-350 w/9' dump bed/4 sp. manual
2013 Escape
1997 Camaro Z28
Lebowski is offline   Reply With Quote
Old 04-08-2013, 12:26 PM   #2
b ramsey
Default Re: Where EXACTLY is the serial number on the frame?
got your ad ready?
b ramsey is offline   Reply With Quote
Old 04-08-2013, 12:47 PM   #3
kwisor
kwisor's Avatar
Hello
mine was under lt fender on top of frame you will need to lossen body and remove fender to find it if there is a lot of paint you will need to wire wheel off to see it behind the motor mount
Kevin
1930 MODEL A TUDOR
1923 MODEL T ROADSTER P/U
kwisor is offline   Reply With Quote
Old 04-08-2013, 12:48 PM   #4
ronn
Hit a different DMV office.... a lot easier.
Old 04-08-2013, 12:54 PM   #5
Stinch
Stinch's Avatar
My frame number is located between the left side engine mount and front running board bracket, adjacent to the front body mount. There is no predictable exact location, only a general area. Your results may vary.
E30 68-B Cabriolet
Stinch is offline   Reply With Quote
Old 04-08-2013, 01:35 PM   #6
Willie Krash
Willie Krash's Avatar
I'm gonna stamp my frame as soon as I find some large number stamps. My guess is they just want to see a number.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 04-08-2013, 01:52 PM   #7
Mitch//pa
i heard of guys stamping the side frame rail just to appease the dmv
Old 04-08-2013, 02:12 PM   #8
Lebowski
Lebowski's Avatar
I live in a small county NE of Louisville which only has two vehicle registration offices. I can't go to an office outside of the county that I live in. I'll try the other one tomorrow. If that doesn't work I may try to find someone to stamp the number on the bottom or side of the frame rail. I'll let you guys know what happens. Thanks....
2013 Escape
1997 Camaro Z28
Old 04-08-2013, 02:45 PM   #9
Fred K-OR
Fred K-OR's Avatar
This sounds like a good plan if you have a number on your title.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-08-2013, 02:44 PM   #10
ford3
the frame # will be any where from the front frame horn to under the body on drivers side, as was stated the fender sits on top of the frame so it has to be removed, get a good wire wheel on a strong drill motor and start cleaning, all the way to bare metal, start looking on top of frame near the steering box, if not there check just in front of the cowl, some times its just under the body, look real close some times they are stamped very light, going by engine # will not help unless its the same as frame #, you do not want two different numbers for one car, get the frame #
ford3 is offline   Reply With Quote
Old 04-08-2013, 03:09 PM   #11
whirnot
whirnot's Avatar
I guess I am lucky, I have a VIN Number on the right firewall.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-08-2013, 03:09 PM   #12
Jim Mason
Jim Mason's Avatar
I have some information on my site.
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 04-09-2013, 12:36 AM   #13
Mike V. Florida
Mike V. Florida's Avatar
This is from Jim's site;
This is the link
Old 04-09-2013, 12:39 AM   #14
hardtimes
hardtimes's Avatar
This is the link
IMO, that would be inaccurate information, in most cases, in todays model a ownership, i.e.- engines seldom same as when built.
Old 04-09-2013, 12:49 AM   #15
Mike V. Florida
Changing the engine out does not make the information inaccurate.
If I say look at a certain page in a book for a quote and some someone has ripped out that page in your book does that make the information I gave inaccurate?
The picture is an accurate representation of where the serial number should be on a model A made in the US.
Old 04-09-2013, 09:06 AM   #16
Franchise_24
Franchise_24's Avatar
I think what he probably meant to say was that the information would not match up if the engine was changed out at some point.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 04-09-2013, 10:24 AM   #17
Jim Mason
Jim Mason's Avatar
And this is why i proved a link to the page rather than just the photo. take a look at the page before you criticize the content as being inaccurate.
http://jmodela.coffeecup.com/numbers.html
Also he asked 'where is the number found' not will the numbers match.
Fwiw, jm.
Old 04-09-2013, 04:02 PM   #18
hardtimes
hardtimes's Avatar
Hey Jim,
THANK YOU! That is exactly my point !
Old 04-09-2013, 04:07 PM   #19
Mike V. Florida
The picture was the short answer and on the bottom of the picture is the link as the "rest of the story".
Old 04-08-2013, 03:32 PM   #20
hardtimes
hardtimes's Avatar
Hey Lebowski,
Ha, ha..'I'll sell it'...that's rich! Now can you post a pic and price !
Yeah, do a 'search' and this has been discussed (with pictures) endlessly.
The stamped number is approximately (give/take inch)..under the rear hood hold down clamp. I can email you pic, if that will help. Even tho my roadster body is on now, I stamped the exact number from top of frame ...to just below that location ON SIDE OF FRAME.
BTW..start unbolting. Hm, mabe one other way to get 'away' with the engine number....tell dmv that you have MATCHING numbers car and splain that . Hey, they might go for it...as guys buy cars with 'matching numbers'..I'm sure..without removing the body.
Oh, by the way, I forgot to mention...that I pulled the body to get the frame number, after the ca chp...said that that was what they would accept. Good luck
