11-29-2017, 02:15 PM | #1 |
Oozing Head Gasket
The Model "B" engine in my 190A has a modern black composition gasket with silicone seals. The cylinder head is a Model "A" from Synder's with 5.5:1 compression ratio. Since this rebuilt engine has been running, there has been a black liquid oozing out of the head gasket.
Thanks Jim Brieley! Last evening while reading your book , "4-Bangers! And Me!", the answer hopped up and bit me. I forgot about the 6 coolant holes near the center of the block that are not in the Model "A" cylinder head. In the past I ran steel and copper head gaskets which effectively blocked those 6 coolant holes. However, the coolant wicks through the composition gasket and is making the mess seen in the photo. I may plug the 6 holes in the block, and I will be replacing the composition gasket with a metal clad one.
Bob Bidonde Last edited by Bob Bidonde; 11-29-2017 at 02:33 PM. |
11-29-2017, 05:06 PM | #2 |
Re: Oozing Head Gasket
Toss the silicone gasket and try a BEST graphite. I had that problem with the silicone only not as bad as yours. My graphite I put on is totally dry all of the way around.
11-29-2017, 05:22 PM | #3 | |
Yeah, you're on the right track ! Some say to just plug the FOUR center holes. I plug them all and with no problems. I've plugged them with the engine in the car and cleaned up like you show yours. Once you 'tap' the holes, I use the 'allen' wrench type plugs screwed down just a little below block surface. Then I fill allen hole and plug hole flush with block surface. Let the filler harded and then touch up even with blk surface. Good luck |
11-29-2017, 05:38 PM | #4 |
Dang!!! That’s ugly
11-29-2017, 06:07 PM | #5 |
Let's let pylons, be pylons! |
11-29-2017, 06:38 PM | #6 |
11-30-2017, 12:01 PM | #7 |
You're welcome Bob! On older 'sandwich' gaskets I have used sealer on the water-jacket edge of the water passages to solve this problem.
11-30-2017, 12:44 PM | #8 |
I have the same oozing on mine. I was ready to pull the head. Now I guess it is more of a nuisance than a problem. Where do I find this "BEST" head gasket?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
12-01-2017, 01:06 PM | #9 |
'Best' gaskets are available at most Model A stores.
