model a engine,new babbitt,ground camshaft,hardened valve seats,new valves,new pistons,rods,new crank and cam shaft gears,used oil pump,transmission used but shifts good.crank has added counter weights.crank and lightened flywheel dyno balanced.new clutch and v-8 pressure plate.no more than 25 miles on engine acc ride around on the farm,just to keep it running.if interested, engine is on chassis,1930 cowl,gas tank,hood,radiator,muffler,tires and wheels,radiator shell for 6000.00 will sell separate or together.was going to build huckster but health went bad.more in formation call ronny 601 596 4144.
