01-31-2024, 11:45 PM | #1 |
Dome lamp and switch
Regarding the two dome lamps installed in the B pillars of a 4 Door Sedan Deluxe, how do you remove the translucent plastic lens without damage in order to replace the bulb ? Thank you ! Kenny C.
02-01-2024, 06:19 AM | #2 |
Re: Dome lamp and switch
Please let us know what year car you are working on.
02-01-2024, 10:42 AM | #3 |
I think there is a small Phillips head in the chrome trim vertically from bottom.
02-01-2024, 10:44 AM | #4 |
If there is no screw in the bezel (need to know year of car) then simply pry the metal bezel off. The lens will stay with the bezel. Do not attempt to remove the lens by itself.
02-01-2024, 11:05 AM | #5 |
02-01-2024, 01:22 PM | #6 |
02-01-2024, 01:54 PM | #7 |
KeeKee: Check and see if you can find a 6V LED bulb that will fit your domelight.
Less heat generated. https://www.amazon.com/s?k=6v+led+bu...sl_y3u62mec5_p |
02-15-2024, 07:11 AM | #8 |
Fordy, Thanks for the bulb info. Kenny
