11-30-2014, 09:22 PM | #1 |
Removing bonded brake linings
Any tricks to removing bonded shoe linings besides hammer and chissel!! Got new ones to rivet on..
11-30-2014, 09:28 PM | #2 |
Re: Removing bonded brake linings
Take them to a brake shop near you.
11-30-2014, 09:38 PM | #3 |
Yes, a bonding oven to heat the glue will cause it to release. Done it many times.
12-01-2014, 04:45 AM | #4 |
You only need to get them hot enough for the glue to let go. I use an LPG torch but have used oxy gear many time too. Just heat then gently while prying the linings with a screw driver or spatula.
12-01-2014, 06:26 AM | #5 |
[B]For the few bucks involved I would indeed take them to a brake shop ! Likely the most important part on your car !
Wayne/B] |
12-01-2014, 11:18 AM | #6 |
12-01-2014, 04:31 PM | #7 |
If you have trouble locating a brake shop, use the yellow pages to find a place that re-lines truck clutches and brakes. They will do it. Thankfully there is such a place in Ft Worth
'31 180A |
