10-23-2016, 08:54 PM | #1 |
Gas Tank Leak
When I bought my tudor, it had a terrible gas tank leak. It was leaking from numerous spots and it was full of rust so I decided to find a new tank and replace it. Luckily, a fellow club member had the exact tank I need so I purchased it from him. The tank was very close to rust free but I decided to have it washed out and pressure tested at a trusted radiator shop. I got it back, installed it. There were no leaks and all was good until today. After 4 months of no leaks, it decided to start leaking at the choke rod support. Now how should I repair it? I almost assume that it needs to come out, which I'm fine with doing but how would I repair in a way that will last me the rest of my lifetime.
10-23-2016, 09:26 PM | #2 |
Re: Gas Tank Leak
Prior to considering welding or soldering, FWIW, I have had success with name brand twin tube epoxy.
Completely drain tank, allow to dry inside thoroughly, remove "all" exterior paint to bare, "clean" oil free metal, mix epoxy according to directions, & apply. Allow to dry a minimum of 24 hours. |
10-24-2016, 08:06 AM | #3 |
Re: Gas Tank Leak
I suppose I'll just solder it. I really don't want to have to deal with this again in 10 years.
10-25-2016, 01:03 AM | #4 | |
Re: Gas Tank Leak
I am very lazy when it comes to cleaning up the site before soldering, just clean it up with a wire brush in an electric drill. But I have never had to redo a fix. To avoid the one time boom Mr. Chauvin mentioned, never use a flame and in a very dry location, ground the tank and iron. |
10-24-2016, 09:42 AM | #5 |
Re: Gas Tank Leak
Hi DJ,
Depending on your heat source for soldering your gas tank, if your tank has internal gas fumes mixed with air, the good thing is ............ you will probably only hear the deafening BOOM once. Just be careful. |
10-24-2016, 11:51 AM | #6 |
Re: Gas Tank Leak
The reason I resorted to it was I had a tank on my huckster that had a bullet hole right under where the bottom of the tank was suppose to be sealed. I took it to a radiator repair shop a number of times to repair but it never did work. So went to the sealer.
10-24-2016, 12:17 PM | #7 |
Re: Gas Tank Leak
Wouldn't a soldering iron do the trick with little risk?
10-24-2016, 04:49 PM | #8 |
Re: Gas Tank Leak
I have fixed literally hundreds of gas tanks.
1. Wash out gas tank with water after removing all fittings,cap etc. (Wash out good) 2. Get rags and plug up all holes (not totally airtight) 3. take old radiator hose hook it into tank behind any car or truck. 4. Let car or truck run for about an hour. 5. Immediately take off the hose plug all holes and solder immediately. Will not blow up. But.............if you wait and let tank sit. The fumes will come back. That's why you want to solder immediately after pulling it off running vehicle. |
10-24-2016, 06:22 PM | #9 |
Re: Gas Tank Leak
Your willingness to take the tank out is a good thing, as you can get the best position of the tank for the work. I agree with post 2, with the exception of epoxy. That is a broad area as there are many epoxies like the JB quickset that I would stay away from. I used the slow cure JB Weld on my column support bracket that leaked. With the tank out you can flip it over and do the prep cleaning and roughing the metal for adhesion. The slow set has a tendency to flow, so I dam it with Fema modeling clay, and after it cures well you can shape it nicely for an original look. Your ahead of the game by the fact there is little stress at that point, and I would feel confident of a successful outcome.
10-24-2016, 06:42 PM | #10 |
Re: Gas Tank Leak
carbon dioxide does not support combustion either
'31 180A |
10-24-2016, 07:28 PM | #11 |
Re: Gas Tank Leak
The steering support on my 29 Tudor was soldered in place, then they added the 31 bracket and left the rubber out of the original bracket. It's been leak free all the years I've owned it since 1992.
A large electric soldering iron or heavy soldering copper would be entirely safe. |
10-24-2016, 09:54 PM | #12 |
Re: Gas Tank Leak
I have used JB Weld successfully with the tank in the car. You need CLEAN metal.
Sewall |
