Good afternoon all !
I just relocated my column shifter from the steering column of my 55 Ford Fairlane to the floor. I would like to find a steering wheel dash bezel that doesn't have the opening for the shifter tube. Did Ford produce a floor shift on this model, so I can find such a bezel or is this just a pipe dream ? I'm open to any suggestions. Thanks Dorf55 |
Ford did not offer a floor shifter on your car. That goes for both standard & automatic transmissions. Which do you have? I had the same problem, as my car had the shifter (automatic) moved to the floor, & had no bezel on it when I got it. So, I mounted a small tachometer on the column, in front of the opening. Looks fine.
1952 Ford F1 !956 Fairlane Club Sedan 1965 Falcon Sprint 2007 Mustang GT |
Thanks for the info, I have a standard shift and I already have a under dash mounted tachometer. its good to know were not the only ones with this issue.
Thanks |
The previous owner of my car mounted a round light in the shifter tube location. This is not a good shot, but you can get the idea.
Very clean appearance - I have the photo(s) but they are on the wrong format. I will try to correct and post. |
