Old 03-21-2022, 01:28 PM   #1
ETAModel
Default Windshield wiper ideas
Hey all, the '30 Fordor didn't have a wiper arm or motor when Edgar bought it, just a small hole in the windshield frame. When I asked someone at the club about it, they told me to just turn around if it starts raining!
I think the '30 had a vacuum wiper, but I could be wrong. The car has the 6 volt, positive ground system.
My question is; what's the easiest way to get some kind of wiper on this windshield? It doesn't have to be 100% P/C, just something that will keep the wiper turning when it occasionally rains here.
I may just use Rainex and be done if its gonna be a major expense/problem.
Thanks in advance.
ETAModel is offline   Reply With Quote
Old 03-21-2022, 01:37 PM   #2
Herb Concord Ca
Default Re: Windshield wiper ideas
Yes your car used a vacuum wiper. You should a 4 holes in the frame on the driver side 2 to mount the wiper, it mounts on the outside. one hole for the slide on/off rod and a larger one for the vacuum line.
Herb Concord Ca is offline   Reply With Quote
Old 03-21-2022, 02:09 PM   #3
ETAModel
Thanks for the quick response Herb. IIRC it does have 4 holes. Many years ago my brother had a car with a vacuum system. I was young but as I recall he didn't have much good to say about it. But he had a lead foot and that caused most of his problems.
So the motor mounts on the outside? Interesting. Where was the vacuum line route from the gas motor to the wiper motor?
How dependable/durable are the reproductions?
Again thanks.
Old 03-21-2022, 02:29 PM   #4
Bob C
Looking at the Standards the Fordor could of had an electric wiper until
around the middle of 1930 when the vacuum wiper was used.
Here is a picture Marco posted.
Old 03-21-2022, 02:49 PM   #5
Brentwood Bob
This YouTube I made may be helpful.
https://m.youtube.com/watch?v=PdKVbOBzhmI
Brentwood Bob is offline   Reply With Quote
Old 03-21-2022, 09:31 PM   #6
Herb Concord Ca
In the engine bay you should see a fitting in the intake manifold and have a metal line from the intake manifold to the firewall. Inside another metal tube from the firewall up the right side to where the windshield is hinged, here it bends (or it may be a rubber hose) is clipped along the top of the of the windshield recess area and go through the windshield frame hole and connect to the wiper.
Old 03-21-2022, 09:55 PM   #7
bruceincam
bruceincam's Avatar
Unless you're worried about originality for some reason, my vote would be to skip the wiper, default to Rainex. If you must have a wiper, make it an electrical wiper. That vacuum wiper is as worthless as ------. I know that you didn't ask for opinions --- I apologize.
bruceincam is offline   Reply With Quote
Old 03-22-2022, 03:54 AM   #8
ETAModel
I was hoping for some opinions. My experience with vacuum wipers is its one step above reaching around the windshield with a hand towel in a driving rain.
No, I'm not worried about originality; its still 6 volt, generator, 4 banger, stock head (I suppose) and other than a few minor details its as it rolled off the line in 1930.
I guess what caused this is we got our first rain in 3 months, so watching it pour down got me to thinking....that's often a bad thing.
We now return to our regular scheduled program, already in progress.
Old 03-21-2022, 11:22 PM   #9
CarlG
CarlG's Avatar
I installed the electric wiper system from Newport Engineering in my '31 CCPU. Works great.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-22-2022, 03:56 AM   #10
ETAModel
CarlG, if I get a wiper I'm leaning towards electric.
Thanks
Old 03-22-2022, 04:23 AM   #11
Karl
Karl's Avatar
I drive my 1930 Phaeton lots in all sorts of weather and I'm happy with my vacuum wiper.
If you get a good one and its rebuild correcty and properly lubed they work fine. I have in the garage a rebuild original electric wiper correct for a 1929 which I ran for a while but really it wasn't any better than the vacuum wiper . The problem with vacuum is that the die cast cases can warp meaning the flapper doesn't seal inside properly- at this point they can't be made any good and you need to find another one -It took me a couple of goes before I found a good one . . I just love it when passengers hear the suck suck of the wiper and I explain how it works . Up hills it will stop but a momentary lift off the gas gives you a few sweeps which is enough -However I'm an original freak
The 34 in my Avatar has twin vacuum wipers which also work well . The 34 has a bleed valve in the vacuum line which means you can vary the wiper speed to suit conditions much more that you would be able to do with an electric wiper
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 03-22-2022, 08:12 AM   #12
chrs1961815
chrs1961815's Avatar
Yes people give vacuum wipers a bad rap because they have worn out ones that are not factory spec. One that has been rebuilt right with paddles that actually seal works quite well.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 03-22-2022, 11:12 AM   #13
katy
katy's Avatar
If you're looking for something inexpensive, easy to install and that works, a hand operated wiper is your friend.
https://www.snydersantiqueauto.com/p...7125&cat=41933
Old 03-22-2022, 12:43 PM   #14
woofa.express
woofa.express's Avatar
I think these hand wipers are great Katy. I found the electric wiper motor partly obscured my vision and my neck ached because I was craning my head to see. Another reason I prefer the hand wiper is because we don't get very much rain and if it is falling too hard I simply stop and wait. That's infrequent.
By my observation drivers seem to go faster in rain. Can't figure that one out?
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 03-22-2022, 02:49 PM   #15
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Get one to fill the hole in your windshield. It doesn't have to work and it probably won't, and then use rain-x
Ivan in southeast va. is offline   Reply With Quote
Old 03-23-2022, 05:53 AM   #16
nkaminar
nkaminar's Avatar
The vacuum windshield wipers were the original variable speed wipers. If they were going too fast you just had to open the throttle. And if they were going to slow you just had to slow down. That said, I loved them. The idea of a vacuum motor and the click-click sound were wonderful.
I have a 6 volt electric wiper motor on my 12 volt car. I added a variable voltage control that mounts with a removable, non-destructive bracket to the top of the windshield. I can now control the wiper motor from very slow to very fast. It still does not do a very good job in the rain.
