The choke wire sold by the vendors is brittle and if you have to “un-bend” the end on the carburetor the wire breaks easily. Am I installing wrong or is there a solution?
Brass wire may not be the best wire to use for a choke pull. I'm not sure if I know a reason to change the pull loop on that wire. Wire in general, can fatigue with any bending, To unbend tight loops just speeds up the process. I would use annealed aircraft grade stainless steel safety wire and form it myself.
If you can locate a factory photo of the bend on the carburetor end, it was a shaped like a straight "Z" so one would pull out on the wire to insert into the choke arm OR only slightly bend the choke arm end so it stays put - it is brittle and you only get one try !
I make my own out of 1/8 steel welding or brazing rod. It's fairly cheep and available.
#5 | |
Enjoy yer day. Tom ![]() Hate can't fix what it started. |
