I am looking at replacing the 6 cylinder flathead in my '48 F-1 pickup with a '47 engine and am wondering if they are the same?
Not sure if you're answer is here, but if you are not familiar with Mac Vanpelts wonderful sight, you should be. Enjoy... http://www.vanpeltsales.com/
I have read that they share very few parts and the G is way harder to source parts for. As for me, the location of the distributor alone is enough for me to favor the H.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Some of the H parts are not found growing on trees.
Bruce
Works good Lasts long time |
I've heard some very late 1947 models had the H-series 226 I6 but that may not have happened. Too many years have passed. The H-series would be the one to find. There is more stuff available for them that is specific to the type since they were the late one that was made through the end of 1951. The G-series was used from 1941 through WWII in 1 1/2-ton trucks and others so they were continued after the war through 1947. They have a different ignition system and there are other differences as well. It may fit but it may be harder to find certain parts that didn't carry over to the H-series.
Sal |
Another thing about the H, is that it can be found in HD Ford trucks, in the 254 ci version.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
Is there a way to tell which H model I have without pulling the head? Casting difference, longer stroke, bigger bore?
That 254" six is 'M' series and it has M cast in the head [49-51] . They are around but scarce. Newc
The H and M six engines have the block part number cast above the oil pan rail behind where the generator mounts. H or M are in the part number depending on which block you have. M motors are not common and the ones around here all seem to be from 1953 two ton trucks.
#11 | |
![]() Quote:
Thanks for all of the comments. I am still not sure if a '47 G engine would directly replace the existing H in my '48 pickup. Are the mountings the same??
#13 |
I have a very dead G laying on it's side in my woods. I have a nice H on a run stand. Both have front motor mounts. The G has a 4 speed on it. The H has a four speed sitting alongside it. It's a hard thing to measure until I mount the trans on the H. Measuring from the center of the front mount's bolt hole to the transmission's mounting surface, the G and H appear the same. Funny, we need the same info, but backwards as I want to put this '51 H in a '47 tonner. I will keep you apprised of details. There is a guy on the '47 and earlier section on FTE (Ford Truck Enthusiasts) forum also getting ready to put an H in a 47 tonner. He looks like he will know the answer soon. Some of my 46-47 tonners have the double set of front mount holes(6 and 8 cyl) and some don't. A mystery.
#14 |
The G engine has a crab style distributor on the front of the engine. The H has a conventional distributor on the driver's side.
M engines were installed '49 to '53 in F-6 and larger trucks. My research indicates that they were used in School buses during the same years. The M engine has a 3.5" bore where the H has a 3.3" bore. Both engines have a 4.4" stroke. The M has heavier H beam rods, a stronger crank and more support in the bottom end of the block. I haven't tried but I am told that all internal parts between the engines are dimensionally interchangeable except pistons. |
#15 |
The M pistons are the same as the '49-'51 Lincoln.
3 ring TRW numbers are L908F, L846F, 4 ring L899F Edit: BTW, it would be interesting to sonic check a H block, to see how much "meat" is in the cylinder walls. Since the V8 could be commonly bored .188 and sometimes .250. There might possibly be enough cylinder wall, to get .200 out of a H?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 02-01-2022 at 04:02 AM. |
#16 |
When was the OHV 6 cylinder introduced? Cars and trucks the same? All I know is that it was before the OHV V8.
Don't never get rid of nuthin! |
#17 |
PeteVS, OHV 6 came out in 1952 Fords.
#18 |
I would like to add that my H engine dropped right into my '47 tonner. Dead center on all mounts, radiator clearance etc. It is necessary to mount the battery tray on the driver's side as the manifolds are on the right. Big surprise was that the front mounts went right into the same frame holes as the V8. Not sure why about half of my jailbar frames have the other frame holes, slightly smaller dia and 3" or so further forward. I'm guessing the G might use the forward holes.
#19 |
Note; There is a NOS M series exhaust manifold on HAMB $300 ! They are very well designed tho compared to a stock H manifold. Newc
#20 |
I had a very difficult time finding a usable camshaft for an H engine. The problem was broken teeth where it drives the distributor.
