Old 03-27-2021, 12:00 PM   #1
Chris in WNC
Chris in WNC's Avatar
Default Magnetic transmission oil drain plug?
does anyone sell one?
believe I've had them in the past but Brattons catalog does not list one.
drained the trans oil today and there were a few little filings in the plug......
our next Model A has arrived.....
Chris in WNC is offline   Reply With Quote
Old 03-27-2021, 12:05 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Magnetic transmission oil drain plug?
A small magnet and a bit of epoxy is all you need to turn your plug into a magnetic one!
Old 03-27-2021, 01:04 PM   #3
George D
George D's Avatar
I made my own for engine trans and rear end using 1/4” long 1/4” diameter high strength magnets I bought online. Just drill into drain plugs 3/16” deep 1/4” wide and stick them in they will hold themselves no glue needed very difficult to get out. When I change the oils the plugs are always loaded with “fuzz” that would have been circulating otherwise. I believe them to be very effective at keeping the oil’s free of fillings. Cylinders wear and everyone grinds a gear now and then.
George D is offline   Reply With Quote
Old 03-27-2021, 01:50 PM   #4
noboD
If it's a pipe thread McMaster-Carr has them. Don't be alarmed the first time you see how many crumbs are stuck to it.
noboD is offline   Reply With Quote
Old 03-28-2021, 08:37 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
I believe that babbitt is non-magnetic. However, cotter pins fatigue and wind up in the pan. What else is magnetic that would stick to a magnetic drain plug?
Bob Bidonde
Old 03-28-2021, 09:53 AM   #6
redmodelt
redmodelt's Avatar
As pistons go up and down the rings take off microscopic scrapings "the black fuzz" of the cylinder walls, esp prevalent after honing the cylinders.
Old 03-28-2021, 10:09 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
I think he is asking about the transmission drain plug.
I agree, McMaster-Carr has magnetic plugs. I also use one in my Mitchell O/D and rear end.
Old 03-28-2021, 05:43 PM   #8
daren007
Never heard of a “Magnetic” transmission.
daren007 is offline   Reply With Quote
Old 03-28-2021, 10:19 PM   #9
updraught
updraught's Avatar
There are no bolts to pull it off. Handy for those that crunch gears a lot.
updraught is offline   Reply With Quote
Old 03-29-2021, 10:32 AM   #10
redmodelt
redmodelt's Avatar
Owen Magnetic https://en.wikipedia.org/wiki/Owen_Magnetic
Old 03-29-2021, 10:08 AM   #11
Dick So. Cal.
Just a point of interest...
I have magnetic plugs in all three locations:
engine, tranny and rear end.
When I pull the plugs to check/drain oil, I always get
some 'dust' on the plugs. Not very much, but a little.
I highly recommend them.
I think I got them at McMaster-Carr.
Dick
Dick So. Cal. is offline   Reply With Quote
Old 03-29-2021, 12:04 PM   #12
ronn
I use HF for magnets. inexpensive.
Old 03-29-2021, 05:22 PM   #13
Synchro909
Synchro909's Avatar
I've been using a magnet on every drain plug (4 per car including O/D) for years. I just put the magnet on the plug and screw it in. It never moves and It's easy to clean when I pull it off the plug. They cost a matter of cents each.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
