Old 09-22-2019, 04:17 PM   #1
Smitty
Smitty's Avatar
Default 1951 Starter 6&8
Does anyone know if the 6 and 8 cylinder starters are interchangeable, I see all kinds of V8 starters but none for the 6-cylinder engine. Specifically looking for a 12 volt starter for H226 engine.
Thanks, Steve
Smitty is offline   Reply With Quote
Old 09-22-2019, 06:03 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: 1951 Starter 6&8
Most of the starters in the 8BA era are the same. The exception is the one for the automatic transmissions. They started to change after a few years into the y-block era.
Old 09-22-2019, 06:19 PM   #3
FortyNiner
FortyNiner's Avatar
I understand that most use the 6V starter after the 12V conversion.
Old 09-22-2019, 07:13 PM   #4
tubman
tubman's Avatar
Yep! Has worked for me for a lotta years.
Old 09-22-2019, 07:45 PM   #5
Smitty
Smitty's Avatar
I had a 6V starter in my Model A, while it worked fine it had a tendency to eat up starter drives. Since I converted the starter to 12V there have been no issues.
Old 09-23-2019, 02:37 PM   #6
toby
toby's Avatar
6 cylinder and 8 cylinder starters and starter drives are the same.
toby is offline   Reply With Quote
Old 09-24-2019, 12:41 PM   #7
amodel25
amodel25's Avatar
I believe the 6 cylinder starters have a 9 tooth drive while the V8 starters have a 10 tooth drive. Check the part numbers.
amodel25 is offline   Reply With Quote
Old 09-24-2019, 01:17 PM   #8
41Joe
41Joe's Avatar
amodel25 is correct. The stock 6 cylinder starter will not interchange with the V8 starter. You will need to either get the correct gear or change your flywheel for the V8. I have a V8 flywheel on my H series with the V8 starter.
41Joe is offline   Reply With Quote
Old 09-24-2019, 09:45 PM   #9
Ross F-1
Ross F-1's Avatar
The Truck parts book shows both 9 and 10 tooth drives used on the H engines, no explanation of why.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
