just discovered no volts to light switch ; replaced fuse to light switch .
no lights head, tail , or parking, no smoke engine starts and runs. what do you suggest I should check ? thanks fordman |
Volt meter and trace back to see where you do have volts.
Thanks - 30-9 1939, 1940 |
Did you check the fuse or just replace it? Was it blown?
yep. the fuse was blown so I replaced it.
Didn't know a 40 had a fuse.
could find original light switch that looked original so I replaced with switch that had a built-in fuse that I installed under dash .
fordman, "kinda" |
Then have you checked the CB to see if you have power out to the lighting switch?
