Old 02-04-2014, 01:30 PM   #1
Tiny
Tiny's Avatar
Default Over heating update
A little back story:
Last spring I rebuilt my water pump, as all it did was leak water everywhere. Before pulling it I ran vinegar for a couple weeks. While the radiator was out I filled and flushed with more vinegar, turning it upside down a vigorously shaking and rinsing. My driveway smelled like an Easter egg factory that day!!! Loads of rust and gunk came out and my radiator drain time went from 7 seconds to 3 seconds. Finally I thought I was in the clear. The car still overheated and went through a lot of water. Anything more than a 10 mile drive and the windshield was wet.
The current story:
Last Sunday I joined my local chapter of MAFCA, The Rambling A's. Sundays breakfast was about 17 miles from my house. I made it to breakfast with some water on my windshield but I made it. How embarrassing to be the new guy with issues. Before I left for home I had to add about 3/4 of a gallon of water. I have long suspected that the water is just being pumped out the overflow and when it gets low enough the car overheats. My first inclination was the radiator must be plugged again so I gave it the drain test. It was still at about 3 seconds to drain. I decided it was time to add a temp gauge I had bought a while ago to help with diagnosis. I was talking with my dad that day and he asked if I had put a thermostat in. I hadn't for some reason, so what the heck I already had the upper hose off to put the temp gauge in and I had the thermostat at the house.
Now armed with a new Stewart Warner temp gauge my son and I took off for a test spin. The temp came up to 140 slowly in my nieghborhood. I turned to my son and said "well that's not enough lets go cruising." We headed out to the Blvd dropped it in high and set out for parts unknown at 45 mph pushing it up to 50 mph at times, still 140. Shasta Dam is about 15 miles or so from the house and there is quite a grade to get up there, now there's a TEST I thought to myself. As I turned left and eased out the clutch and began the climb I turned to my son and said "Well if we make it up the ride down should be a good test of the brakes!!!!" He didn't find this humorous!! I was dying laughing he was a little pale.
I'm happy to report I only reached 143 and the brakes were fine, I knew they were I just like messing with the boy.
Here is the proof!!!!!!!!
The lake sure is low though.
We could use a lot of rain
So for all the non-believers, I think a thermostat solved my issues. I think it slowed the water down enough to keep it in the system. Next I may put an overflow on it just to make sure I'm correct.
And yes my radiator has the deflector plate in the top tank.
Blackwall Panthers
Nor Cal chapter
Tiny is offline   Reply With Quote
Old 02-04-2014, 01:47 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Over heating update
The thermostat acts as a flow restrictor even when its open. Installing a ten penny common nail in the top of the overflow tube like brother Bill says would probably have worked just as good. I grind the tips off the water pump impeller vanes to curb the flow. As long as it doesn't stick closed, a thermostat will do the job.
Old 02-04-2014, 01:58 PM   #3
Tiny
Tiny's Avatar
I wish I could do Bills nail trick but the overflow was pinched party closed by someone in the past and I haven't come up with a good way to unpinch it. As it sits now a nail won't fit. I've tried. I do have a bit of rubber hose on it to extend it up to the bottom of my quail though.
Blackwall Panthers
Nor Cal chapter
Old 02-04-2014, 02:39 PM   #4
Keith True
Keith True's Avatar
Tiny,you can put a cap-plug on the end of the overflow,the kind that comes on the ends of new fuel lines and such.Then cut a little X in the end of it with an exacto-knife.It won't build any real pressure,but the water won't sneak out of it either.If hot water is hitting the windshield then the cap is not sealed properly.I do not own an A with a properly sealing cap.They all have some defect that lets the water dribble out at from time to time.I may even fix one sometime.
Old 02-04-2014, 04:13 PM   #5
Purdy Swoft
I finaly stopped the leaks around the repro quail cap on the 31 coupe. I used the high temp silicone gasket sealer under the gaskets. I'm running an original radiator cap on my roadsterand so far so good.
Old 02-04-2014, 04:22 PM   #6
700rpm
700rpm's Avatar
I'm glad you got that figured out Tiny. I went through the same exercises last spring without favorable results. I finally took the radiator into a shop and had them rod it out. They were amazed it circulated any water at all, it was so clogged with rust and gunk. Looking forward to a happier and cooler touring season this year.
Ray Horton, Portland, OR
Old 02-04-2014, 04:29 PM   #7
Gil Sissons
Tiny....you got away much cheaper that I did with the same problem on the 31 Vicky. It took a new Snyder Head & gasket for me...but very good results since then. Gil NoCal
Gil Sissons is offline   Reply With Quote
Old 02-04-2014, 04:36 PM   #8
Tiny
Tiny's Avatar
Ray that's where I though I was headed next and wasn't looking forward to it either.
Thankfully I solved it for zero dollars, as both the gauge and thermostat were bought with 2013 dollars!!
Gil I would like to "Hop Up" my motor a bit also but with a rebuild date of 060945 on the side of the block I'm going to wait for a fresh motor for Go Fast goodies
Blackwall Panthers
Nor Cal chapter
