Old 12-07-2015, 06:54 PM   #1
Talkwrench
Talkwrench's Avatar
Default Advice - starting an old engine
Hoping to get a little advice from you guys just to back me up. On the weekend I have to take a look at a vehicle that we need to try and get running for a film crew. Its a very famous and unusual vehicle its an amphibious jeep fitted with what I would think a flathead 4 cyl Ford engine. I believe it was running about 6 years ago. What procedures would you use?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 12-07-2015, 07:05 PM   #2
alanwoodieman
Default Re: Advice - starting an old engine
remove the spark plugs and pour 1/2 automatic trans fluid, 1/2 acetone into the plug holes and let soak for a couple of days, or at least overnight. place vehicle on level ground, put into high gear and rock it back and forth while observing the fan pulley to see if it moves. most of the times either the rings are sticking or the valves in the guides--especially if it is a Ford flat head
alanwoodieman is offline   Reply With Quote
Old 12-07-2015, 08:35 PM   #3
SofaKing
SofaKing's Avatar
You don't mention storage conditions. I'd start with fresh petrol and battery, wire brush any carbon off the plugs, make sure it has oil and see if it will light-off. If it does, change the fluids, give it the once over, check the brakes and see if you can be an extra!
SofaKing is offline   Reply With Quote
Old 12-07-2015, 08:35 PM   #4
VeryTangled
VeryTangled's Avatar
Hi Everyone, My two cents, take extra power sources, batteries and chargers.
Something to squirt some fuel with.
Air if they are expecting it to roll. Jacks, skates if you have them.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 12-07-2015, 09:53 PM   #5
Talkwrench
Talkwrench's Avatar
I think the idea will be to assess first but if we think everything looks ok we may give it a go with what we have. There is a mechanic coming out however I just want to make sure its done right if we attempt to start it. Cant afford to stuff it up with a gung-ho attitude. This vehicle has a famous history so it deserve a bit of respect now. It has been kept in an enclosure however I have been told that there are air gaps around the roof and walls so Im hoping no creatures have go in. We are not too bad here with mice , wasps etc fingers crossed.
Would there be anything wrong with using just a bit of oil down the cylinders?
I think one of the hardest things might be even finding the battery[s] on this thing and getting to the engine and parts...
Old 12-07-2015, 10:11 PM   #6
Mike in AZ
Mike in AZ's Avatar
points file.....file the points to make sure there's good, clean contact.....should be 6V...hmmm...maybe 24V....here's a link to one for sale??.....or at least what i think you're describing....a Seep....good luck....Mike
http://www.armyjeeps.net/FordGPA6-9X/fordgpa.htm
Mike in AZ is offline   Reply With Quote
Old 12-07-2015, 10:44 PM   #7
Kurt in NJ
Kurt in NJ's Avatar
much depends on how it was put away---it could of had regular non detergent oil and now has a 2 inch layer of sludge in the bottom of the pan, start by looking at the dipstick, if the oil looks clean try to drain it ---if it comes out most likely you are ok, if you have to poke a hole in the sludge to get it to drain you should start by dropping the pan to clean it out
the points will most likely be corroded and need to be cleaned
look in the fuel tank, hopefully dry and clean,
Old 12-07-2015, 11:57 PM   #8
David J
David J's Avatar
Good idea to loosen all drain plugs slightly and let out any condensation before it gets mixed with oil or gear lube . Clean fuel of course and I like to take all spark plugs out and squirt a little oil in there . You should be able to get some on the valve guides also . Leave the plugs out and check fluids and spin it with the starter till you get oil pressure . Rest is pretty obvious . Good Luck Dave
David J is offline   Reply With Quote
Old 12-08-2015, 01:18 AM   #9
J Franklin
J Franklin's Avatar
Fresh oil for sure.
Old 12-08-2015, 04:34 AM   #10
Talkwrench
Talkwrench's Avatar
Mike I would say that is what we'll be looking at but modified for ocean crossing .. yes I said that right.
Old 12-08-2015, 05:01 PM   #11
Lawrie
Lawrie's Avatar
If you get that thing going Rob,you could cruise on around in it.
Lawrie
Lawrie is offline   Reply With Quote
Old 12-08-2015, 05:07 PM   #12
Willit Stop
Willit Stop's Avatar
My little 21 stud sat around for 20 years and it fired right off.
Willit Stop is online now   Reply With Quote
Old 12-08-2015, 06:56 PM   #13
Talkwrench
Talkwrench's Avatar
Well Lawrie I think the main thing is [as above] will it stop ..? It does need a caretaker the poor old gal. I hope the story will get out about this particular vehicle and it becomes a motion picture its quite a story. It was in a museum in the USA then was purchased and it came here back to where the original owner was from. If we get it started guess I could put it in low range and just run around the oval. I think its like "today tonight" or "Sunday night" one of the Australia wide crews are coming out to do the story in the middle of January. So look out for it Lawrie ..
Old 12-08-2015, 07:07 PM   #14
Karl Wescott
Karl Wescott's Avatar
This wouldn't be the "Half-Safe" driven/piloted by Ben Carlin? https://en.wikipedia.org/wiki/Ben_Carlin.
If it is a GPA didn't they use the same flathead 4 as the Willys military jeeps?
Karl Wescott is offline   Reply With Quote
Old 12-08-2015, 07:43 PM   #15
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Somewhere around 1940 the Military gave Ford the rights to build Jeeps like the Willys parts, the 4cyl flathead 134ci, most of the engine parts were same as Willys, except thay had timing chain instead just gears, the cam turned the other direction, every part on the engine had the letter f on it, every head bolt had f on the head. The tail gate had FORD on the back. Willys couldn't make them fast enough for the Military. I've built a few of them. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 12-08-2015, 07:45 PM   #16
jacob smith
jacob smith's Avatar
Is that jeep on display at a school
Ford
jacob smith is offline   Reply With Quote
Old 12-08-2015, 07:50 PM   #17
SofaKing
SofaKing's Avatar
Do you have to start it the first time on-camera?
Old 12-08-2015, 08:59 PM   #18
Talkwrench
Talkwrench's Avatar
Hey good idea I'll try remember to do it.
Jacob . yes is all Im going to say at this point ; )
Karl ... shhhh!
Old 12-08-2015, 10:31 PM   #19
Mike in AZ
Mike in AZ's Avatar
"ocean crossing"?.....hope there aren't many waves.....Mike
Old 12-08-2015, 11:55 PM   #20
34billct
34billct's Avatar
I'd bring a can of starting ether.
34billct is offline   Reply With Quote
