#1 |
I'm new to the early V8's so please be patient with my stupid questions...
I have a 53 Mainline with a stock 239 and want to swap from the little chrome air cleaner back to the original oil bath. My brother happened to have one off his old flathead from years ago that is in very good shape. I was wondering if people who use the oil bath are actually using oil in them or if they are running dry? I want to know more about the oil bath...any information would be helpful! Thanks! Kevin |
#2 |
The oil bath air cleaner was designed to use the oil to catch dust/sand, etc. before it could get into the carburetor. Using an oil bath without oil is tantamount to running no filter element in a non oil bath air cleaner.
#3 |
Thanks Vic! The screen does look pretty porous. So is there any advice on using them as designed with oil? Can they be problematic? The little chrome air cleaner that came on the car takes the dignity from Henery's flathead and I want to stay original looking...
#4 |
The only problem you'll run into, is spilling oil when you remove the air cleaner...
#5 |
What is the best method to clean it? It has been sitting for many years with oil in it. It's not rusted at all. I'm assuming there is sludge in the screen.
#6 |
#7 |
I'm still rinnin' one on the '50, and yes remember to keep it level when removing it or you'll have a mess.
Gene |
#8 | |
![]() Quote:
#9 |
Yep.....oil in it.
Careful with the decals.... Dab, don't rub. ![]() Bob ![]()
..."they are only original once" |
#10 |
51MERC-CT, does anyone make a conversion for a paper element for the old oil bath system?
Gene |
#11 | |
![]() Quote:
#12 |
You can get paper filters that will fit in place the wire mesh goodluck
#13 | |
![]() Quote:
Gene |
#14 | |
![]() Quote:
This one was done to mount on top of the inlet with the lid as the cover. A larger filter can be utilized to fit down into the filter base with a spacer to fit under the lid. There are different ways of doing it, all depending on the imagination and ability of who ever is doing it.
#15 |
I don't know of any tests that show replacing the oil bath function with a paper filter is better (for old Fords, low mileage, paved roads). But guys are always trying to "improve" their Ford. Cutting or uncrimping the top destroys the ability to return to oil bath. And hard to find another one. Like Vic says, it is a messy job (1 hour) to clean and re-oil but keeps the car as built. JMO
John Last edited by oldford2; 09-04-2014 at 11:43 AM. |
#16 |
I don't mean to hi jack this thread, but is there a way to ID the air cleaner as to what is proper for what year? I have an oil bath air cleaner with no markings on it other than "oil level". I have a dry filter (brillo pad style) with "HH" stamped into the bottom. With all the sub contractors that Henry used, I have to assume that any markings would be from a subcontractor. But what sub contractor made the air cleaner for what years?
#17 |
A caution, I was always warned, never tested tho, the inside seams are like knife edge. Take care not to run your fingers on the inside seams.
#18 |
Funny thing.... I was tuning my flatty and it back fired and blew the loose oil bath air cleaner clean off...that little pint of oil went every where. Including all over me....ha.ha now..not then
Randy |
#19 |
I jus bought one for my 53 engine 94 carb they are not the same as 97.
make sure you get the right bottom. No oil is ok in my book nothing can crawl in carb ,back fire and you don,t hear the noise going down the road. |
#20 |
Here is a liink from the HAMB.
Hope this helps if you want to convert. Torchie. http://www.jalopyjournal.com/forum/t...o-paper-dry-ty |
