#21 |
We install a modern paper filter element in oil bath air cleaners. It certainly does away with the oily mess, and gives filtration equal to that of modern cars. We did a sheet on it years ago. I'll try to find and post it if you want it. The attachment process on this site is certainly cumbersome, and I still haven't mastered it yet. If oil bath air cleaners were more efficient than paper, there would be no paper. Henry Ford had no love for filters. The air horn on the Model A's faced rearward, as he believed that the heavy dust from the roads of the time would pass by the intake as the vehicle moved forward.
#22 |
Hi Bob (Supereal)
Back in 2008 you had a post on EFV8 concerning the change from oil bath to a paper filter. You e-mailed me pictures and instructions on the procedures. It looked interesting so I bought the proper filter and started the project. Stopped when I realized that uncrimping the top from body was irreversible. So the paper filter is still in my stash. My 46 is very original and I decided to change as few things as possible. I still think that a properly maintained oil filter will not cause any extra wear (compared to a paper filter) on the bearing surfaces and that the change is unnecessary. JMhumbleO John Last edited by oldford2; 09-04-2014 at 07:45 PM. |
#23 |
I have both for my 53' Merc. I used a Plasma cutter to cut the mesh out (it caught on fire - no surprise due to the oil in the mesh, so keep a fire extinguisher handy) The filter is a K&N E-1290. I find they both seem to work equally as to air flow. Since it is a K&N filter the bottom line is that it still uses oil for filtration.
Goal was to make one with a filter that looked origional. Last edited by Merc Cruzer; 09-05-2014 at 07:11 AM. |
#24 | |
![]() Quote:
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
#25 | |
![]() Quote:
#26 | |
running the "oil bath" dry could cause it to clog up, the oil circulating in the filter cleans the mesh, cleaning the oil bath means cleaning all the grunge out of the oil sump, and filling the oil to the proper level |
#27 |
We converted oil bath air cleaners to paper elements a long time ago. I still have the instruction sheet if anyone wants it. You do have to pry up the edges of the lid to install a metal disk in the top, but if you are careful, the original "top hat" can be reinstalled, if desired by prying up the edges again, than re crimping. Once you convert, unless you are a purist, I would stay with the modern element. The only engines that still use an oilbath filter are mostly offroad equipment and large trucks. Those use a "whirlwind" to allow the oil to catch the dirt, where the old type depended on the inertia of the particles to cross the surface of the oil pool, which was not as efficient.
#28 | |
![]() Quote:
#29 | |
![]() Quote:
Thank you for the reply. I wondered if it could be done...now I know! |
#30 | |
![]() Quote:
http://deepblue.lib.umich.edu/bitstr...pdf?sequence=5 if you want to prove it wash the element dry, just fill the oil to the proper level and go for a drive ----I have done this too, the filtering mesh gets oiled, the design is such that excess oil drains back, carring dirt with it |
#31 |
Does the mash in a oil type filter have to be cleaned with gasoline or some other type solvent on some type of schedule?
#32 | |
![]() Quote:
#33 | |
![]() Quote:
#34 |
The incommong air puts a wave action on the oil causing it to percolate up into the metal mesh with the aid of the baffle. The air just passes through the oily mesh. The oil lightly percolates up into the mesh as long as air is flowing. No filter removes all contaminants but the oil bath is efficient enough. Cleaning them is a chore since most of the dirty air drawn into the thing has a fine talc along with that is very difficult to flush out. I just scrape the stuff out after washing most of the oil residue off. Paper filters are definitely easier to service. Give it a fling and install a new one. No muss no fuss. The military still uses a lot of oil bath type filters due to supply concerns. Rather than stock a bunch of filters, all they have to stock is something they already use, motor oil. Now getting the troopies to clean the filters out properly is a another problem. We had them on the generator sets, air compressors, and a whole list of other motorized equipment. If the operators didn't clean them then soon there was no room for oil anymore.
#35 |
I was always told to soak them in kerosene and it seems to work rather well. I service a car that claimed to have vaporlock issues but turns out his oil bath filter was so clogged that it was causing the engine to run rich. As soon as he shut off the car it would be flooded and take a bit to get it to start again if hot.
#36 |
Yes, oil drawn into mesh by slow and dripping back down is certainly part of the system.
The oily mesh traps the lighter particles and drips most of them back down with the oil after the heavy stuff is carried by its momentum straight down into the sump. Ford mentioned in bulletins that the normal hat type oil baths will hold about a pound of crud, the big offset heavy duty ones three pounds! A long soaking of the mesh is important on old ones...if they were run too long with dirty oil the mesh could become blocked with petrified oily crud, making the thing restrictive and inefficient in all ways. With most designs the mesh can be hung down into solvent with the painted top safely out of the soup. |
#37 | |
![]() Quote:
http://1954ford.com/forum/viewforum.php?f=20 You can also find him here: https://www.facebook.com/groups/54FordClub/ As Don Allen,pictures were available. |
#38 |
The oil bath achieves a maximum separation efficiency of approx. 98.5% and is therefore not as efficient as the filtration performance of a modern dry air cleaner
(> 99.95%). This information was taken from the following web page: http://www.krone-filter.de/assets/fi...ann-hummel.pdf If 98.5% is not good enough then use a paper filter.
John Live for today, but save for tomorrow! |
#39 |
LINK DON'T WORK. Leads you off on a tangent.
#40 |
I think I'll use what Henry used.....
![]() ![]() Bob ![]()
..."they are only original once" |
