02-07-2016, 05:04 PM | #1 |
Rope rear main seal in early engine
So at some point I am going to go through the original engine in my 39 Merc. Although it will remain stock in outer appearance I intend to use my 4" crank and 8ba rotating components. Regarding the rear main seal am I correct that the die cast parts in the slinger area are simply replaced by the die cast parts from later engines that can hold the rope seals?
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
02-07-2016, 07:04 PM | #2 |
Re: Rope rear main seal in early engine
You'll need the lower 19B-6336 holder for the lower rope.
02-07-2016, 07:22 PM | #3 |
Thanks for the response Ken, but is there not a corresponding upper holder that fits in the block, or is there just a groove that the rope goes in. Obviously have never had a pre '49 engine apart.
02-07-2016, 08:16 PM | #4 | |
02-07-2016, 10:06 PM | #5 |
Thanks again for your info, and your part numbers are spot on. I would be surprised if my '39 Merc already had a rope rear main seal, but we'll see when we open things up!
