Old 10-20-2024, 01:58 PM   #1
acchaplin
Default Bleeding brakes-pedal pressure problem. Could use some advice/suggestions
Here is what I have.
Mostly early production '32 frame, steering, etc.
'53-'56 PU front brakes.
'39-'42 rear brakes. ALL the brake components are new except for the drums. They have been turned originals.
Front brakes are adjusted to a slight drag. Rears are not adjusted. (need 25-35 pounds of force applied to brake pedal)
Master cly I think, (bought it too long ago, you know, CRS) is a non power Mustang. Hardly any "free pedal travel")
Brake lines are 1/4" all polished stainless, with double flaired ends and polished brass T's.
Bleeding procedure. Master cly was bench bled by the instructions. Fill, until fludi starts to run out ports, then cap off with the plastic plugs. Short quick strokes until resistance.
Rears first. 5 pedal pumps then hold. Ran 1/2 a bottle of fluid thrugh. Got air bubbles, No hi pressure fluid squirts, just some soild dribble. The pedal would freely go to the floor.
Fronts, the same way. 5-10 sometimes 20, pedal pumps then hold. Got some air bubbles at first, then just some solid dribble fluid. Finished off that quart bottle of fluid.
Pedal would freely go to the floor.
I should ad, that there are NO visible leaks.
If I would pump the pedal fast and hard, I would get about a 1/4 pedal, and it would hold. Let up, pump again one time, pdeal would freely go to the floor.
Pump the pedal fast and hard several times again, get that 1/4 pedal. One could, with much difficulty, turn each wheel by hand.
What procedure am I missing here? Thanks
acchaplin is offline   Reply With Quote
Old 10-20-2024, 02:47 PM   #2
kurt v
Default Re: Bleeding brakes-pedal pressure problem. Could use some advice/suggestions
don't know but have you adjusted the cyl so that the piston can come all the way back to pick up more of the fluid ?
kurt v is offline   Reply With Quote
Old 10-20-2024, 04:41 PM   #3
Bob C
Sounds like no residual pressure valve.
Old 10-20-2024, 04:50 PM   #4
Flathead Fever
Flathead Fever's Avatar
I was a fleet mechanic for 30-years and have bled hundreds if not thousands of brakes. Every once in a while, you get one that's a pain in the butt, it's hard to get the air out of it. I would go ahead and adjust the rears as close as you can, you can go back and finish the rear adjustment once you have the brakes bled. Don't forget that the rear early Ford rear brakes you used have the long shoes towards the front, the opposite of every other drum brake on the planet. Adjust them up tight and then try bleeding the brakes. If it still causing problems, they make a visegrip with smooth edges that is made for clamping off hoses. Clamp off the rear brake hose and see if the pedal comes up, that way you can tell if the air is trapped in the rear or somewhere else. I have plugs for the master cylinder too. I can remove the lines and plug the holes, and the pedal should be rock hard.
When you bleed brakes pump the pedal slowly not fast. Pumping it fast can break the air up into tiny bubbles making it harder to get it out. You want to slowly push the air down the lines and out the cylinders.
Old 10-21-2024, 09:45 AM   #5
rich b
rich b's Avatar
Adjust the brakes tight; fronts with the star wheel, rears with the two top adjusters. Might be all you need to get a hard pedal; then go back and properly adjust the brakes.
Since you sound a little unsure on the master; maybe pull the boot back and make sure it is a 1" bore.
Old 10-21-2024, 11:51 AM   #6
deuce_roadster
deuce_roadster's Avatar
I would check what KurtV said first. You need a small bit of freeplay in the brake pedal so the piston comes all the way back. Also, if the MC sat for years with no fluid in it, perhaps it isn't working correctly.
deuce_roadster is online now   Reply With Quote
Old 10-21-2024, 05:59 PM   #7
acchaplin
Yes! There is just under a 1/2" free pedal travel.
Old 10-21-2024, 06:11 PM   #8
acchaplin
Yes, it is a 1" ID bore.
The reason I am unsure of what vehicle the MC originally goes to is I bought it 3-4 years ago. I was getting a number of items ready for a certain color at the local powder coaters. The MC was one of those items. I pulled the MC "innards" out in order, wrapped them in a brake fluid soaked rag then put that into a sealed plastic sandwich bag, then placed in the back of the cabnet untill I was ready for them here 3-4 weeks ago, when I assembled and installed the MC. After the MC was powder coated, I shoved a rag in the bore and sealed it with one of those plastic tubing plugs, then put the chrome bail and lid on, put all that into a plastic bag, and it went into that same cabnet.
I have run all the brakes up tight, like you sugested waiting for a family member to stop by and help me.
Old 10-21-2024, 06:14 PM   #9
acchaplin
I don't see why not it shouldn't be working. I sealed it up good 'n tight in the dark reaches of a cabnet I seldom go into,
Old 10-21-2024, 06:19 PM   #10
acchaplin
Soon as I get someone to help me, (son-in-law, and grandson were here on Sat) Might have to wait until next Sat for help.
I will post what my findings are.
This should be a SIMPLE task. A dual port MC, plumed into OEM front drum brakes, and rear drum brakes. That's it.
Old 10-21-2024, 07:18 PM   #11
paul2748
paul2748's Avatar
Is the master cylinder a drum/drum unit.Disc/drum masters are different, most do not have a residual pressure valve built in.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-21-2024, 09:33 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
Does the linkage move the master cylinder piston through its full stroke?
Have the wheel cylinders been examined to see that the bleeder holes were drilled to be at the top of the wheel cylinders?
Have the shoes been fit to the diameter of the drums?
Has the centering of the shoes been checked?—-
Old 10-22-2024, 12:20 AM   #13
Lanny
Lanny's Avatar
acchaplin, curious, are using glycol brake fluid or silicone brake fluid ?
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 10-22-2024, 10:39 AM   #14
acchaplin
Yes, I am pretty sure it's a drum/drum, non power MC. If I remember right, this pictulair MC was reccomended to me. Early '60's Mustang.
Old 10-22-2024, 11:14 AM   #15
acchaplin
There is no "linkage",,,,,,,,,,,. Original pedal assembly, with a aftermarket MC relocation(?)/remount kit. Bracket bolted to the original holes in the K-member, allowed a later MC to be mounted.
The only thing I canged was the steel brake rod supplied in the kit. (goes from the bottom of the pedal va a clevis with the rod threaded into it, directly into the MC). Made it out of 304 stainless and added a little 1/4-3/8" to the overall lenght, and half dozen more threads.
There is no one around here that can do that "shoe fit to the drum" thing any more. Place was bought out in the early '90's. Just tell you to "drive aroun the block" several times, or "come down Cheat Mtn on 50 one time." They will be seated in no time.
As far as "centering",,,,, I don't know. The shoes and hardware mounted up only one way. Here is a picture, you can please tell me if you see something not correct. Thanks
Old 10-22-2024, 12:28 PM   #16
TJ
TJ's Avatar
You have the early rear brakes and did you adjust the bottom anchors? Also you powder coated the MC. Did you powder coat the lid? There is a vent hole in the top, is it clear?
TJ is online now   Reply With Quote
Old 10-22-2024, 01:43 PM   #17
glennpm
glennpm's Avatar
First, exactly what Mustang brand and model number did you buy?
As TJ said, make sure the MC air bleed hole is open
Looks like you put chrome acorn nuts on the bottom adjusters which is not correct.
The way to adjust is shown in the attached Ford bulletin.
The bottom studs have flats on them with a punch marks as shown below
File Type: pdf Brake adjustment from Ford_Bulletin.pdf (78.5 KB, 17 views)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 10-22-2024, 01:48 PM   #18
glennpm
glennpm's Avatar
I was a fleet mechanic for 30-years and have bled hundreds if not thousands of brakes.... If it still causing problems, they make a visegrip with smooth edges that is made for clamping off hoses. Clamp off the rear brake hose and see if the pedal comes up, that way you can tell if the air is trapped in the rear or somewhere else
Just slip hose over the jaws.
Rumble Seat's Notes
Old 10-22-2024, 03:36 PM   #19
acchaplin
No. The lid and bail are chromed. Yes the vents are open because the rubber lid gasket/bladder sucks itself down into whichever MC port I happen be bleeding.
Old 10-22-2024, 04:07 PM   #20
acchaplin
Originally Posted by glennpm View Post
first, exactly what mustang brand and model number did you buy?
As tj said, make sure the mc air bleed hole is open
looks like you put chrome acorn nuts on the bottom adjusters which is not correct.
The way to adjust is shown in the attached ford bulletin.
i have that bulletin of yours enlarged and hi-lighted.
Way ahead of you on the acorn bottom adjusters. Those larger stainless, chrome (depending on size) acorn nuts are from iowa 80 in walcott. They are press on covers. So the bottom adjusters do work. However i have not adjusted them as per suggestions from above.
I do not know which mc i did buy, or even where i bought it from. My receipts only go back 3+ years. It was either advanced or napa. I do remember having to return one mc because it would not match the adapter mounting holes. Even the 2nd mc (the one i had powder coated) i had to elongate the mounting holes around a 1/8" on each side.
If i had grandson take a picture of the mc, could you tell what it is by the pictures? Thanks
abc
