12-07-2010, 08:53 AM | #1 |
fuel line fittings
Installing a new line from tank to engine.I have the ends of the old line.One end has a compression ferrule,the other end has been flared.Does the compression ferrule go into the tank,or does the flared end.Thanks.
12-07-2010, 04:22 PM | #2 |
Re: fuel line fittings
Al both ends of the fuel line are the same 1/2"X20 threads with 1/4" compression ferrules. The same fittings are used on both ends of the pump to carb line. Weatherhead makes the fittings and they are called Ford fuel line fittings. Napa should have them or be able to get them. If you can't find them Bob Shewman [email protected] has some. He is in Kimberton, Pa. 1-610-933-6637 G.M.
www.fordcollector.com |
12-07-2010, 07:55 PM | #3 |
Uncle Max has a large quanity of the Ford 1/2X20 fuel line fittings. These original types come with the ferrule pushed into the fitting. The ferrule breaks loose and crimps on the fuel line when tightened. There is a 1/4" recess in the pump and other places the fuel fittings are used. Push the tubeing in to make sure it is in the recess before tightening to make the crimp. I like to make the crimp in another fitting so I can look at it before putting it in the pump, carb or tank or line fittings. G.M.
12-07-2010, 09:48 PM | #4 |
Thanks,G.M.,I like reading these innovative things ,that add some extra quality.
12-08-2010, 08:12 AM | #5 |
I'ts called FORD NUT, Try Napa Auto Parts
Edelmann #108400 Weatherhead # 59X4 Everco # 8 |
12-08-2010, 09:46 AM | #6 | |
After I learned that the manufactuers of these nuts stopped production, I had a large order made myself in the USA. These are exact reproductions and look and work as original. There is a large supplier of Ford parts who sell a nut that is supposed to be like original, but the things are METRIC.(made in China I guess). Edelmann, Weatherhead or Everco do not supply the Ford nuts anymore. |
12-08-2010, 10:08 AM | #7 |
And also do not buy the ones from Mac's,they are not even made with a simple basic machining principal,inside is not concentric with the outside diameter and I think they were made in the USA . Bought good correct ones and fuel lines from Mr. Jerry Grayson like I had 35 years ago and like I should have last time instead of trying to fill a mail order to justify shipping.
"Never complain,never explain"... Henry Ford II |
12-08-2010, 11:19 AM | #8 | |
12-08-2010, 06:01 PM | #9 |
I have used 50 or more of the fittings called "Ford Special Nut" manufactured by Weatherhead one of the most complete suppliers of brass fittings. I never had a problem with one of them. Go to www.royalbrassandhose.com click on catalogs and then click on "entire brass fitting section" then scroll down to page 36 and the fittings are displayed. G.M.
12-08-2010, 06:23 PM | #10 |
I just stumbled onto a box of 100 Edelmann Ford Nuts (two piece w/ferrule), if anyone needs some.
12-09-2010, 12:38 PM | #11 | |
