Old 11-05-2018, 08:23 AM   #1
john greco
Default Converting to 12 v
What do you have to do to convert to 12v as far as getting fuel , oil, amp , temp gages to work ? Thanks
john greco is offline   Reply With Quote
Old 11-05-2018, 08:49 AM   #2
TJ
TJ's Avatar
Default Re: Converting to 12 v
First why do you want to convert? Second what year car are you wanting to convert? A good 6 volt system with proper grounding, the correct size battery cables, a good charging system , and a good battery will work just as good as a 12 volt system.
Old 11-05-2018, 08:53 AM   #3
JSeery
JSeery's Avatar
Need to add a voltage reducer to the power wire(s) going to the gauges. The electrical path is from the power input to the gauges to the senders, the senders provide the path to ground. Ford used a voltage reducer when they switched to 12v, believe the same basic arrangement was used into the 80s. You can add one voltage reducer that feeds all of the gauges or individual reducers for each gauge. There have been a lot of past threads on 6v to 12v conversions, here are a couple:
https://fordbarn.com/forum/showthrea...oltage+reducer
Old 11-05-2018, 09:13 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Yes, indeed, a single Ford instrument cluster voltage reducer is all you need.
This is similar to what I am using with the only variation being in the way they mount depending on the original application.
Old 11-05-2018, 09:43 AM   #5
JSeery
JSeery's Avatar
That is similar to the 1966 Mustang Voltage Reducer if you need a model year. This is interesting:
Old 11-05-2018, 10:31 AM   #6
19Fordy
19Fordy's Avatar
John, When I converted to 12V I used a Constant Voltage Reducer from Ron Francis that allowed me to feed 6V to the gauges. Do a search and find tons of info. Flat Ernie has provided oodles of top notch tech info too. Just type "Converting to 12 volts" into the Search Box and lots of good info. pops up, like this:
https://www.fordbarn.com/forum/showt...olt+conversion
Here's some Ammeter info.
https://www.lectriclimited.com/legac...conversion.htm
Old 11-05-2018, 11:14 PM   #7
fordor41
fordor41's Avatar
I used a Ron Francis VR-1 voltage reducer to operate the gauges on my '41 but I had changed my gauges to mid '70's Ford.
fordor41 is offline   Reply With Quote
Old 11-06-2018, 03:25 PM   #8
19Fordy
19Fordy's Avatar
Mine's a VR-1 also.
Here's Flat Ernie's input. He recommends CVR for accuracy.
https://www.fordbarn.com/forum/showt...oltage+reducer
