Hello,
I am thinking of adding an accessory fuse panel to my 6 V model A to accommodate the additional accessories I plan to add to the car. When I purchased the car it already had turn signals and I have already added a 6 V electric wiper. I am planning to add a domelight, driving lights, back up lights and a USB port to charge my phone. Before adding all of the accessories I was thinking it made sense to plan out what the wiring would look like and add an accessory fuse panel and I saw the one on Snyder’s website part number A-14304. It looks like it would do the job that I wanted to do, but I was wondering if anyone else had used this or any other accessory fuse panels available? I guess I have a follow-up question also which is I only have a amp meter that goes plus or minus 20... do I need to replace the amp meter with something better? Thank you for your feedback.... Last edited by bdtutton; 07-24-2020 at 03:18 PM. Reason: Expand question... |
You will likely need an alternator to pull the current you will need for an increased load. The old 3-brush only puts out enough to run the lights without overloading anything.
I guess I did forget to mention that I do have a very nice touring alternator that puts out plenty of power to drive the accessories I plan to add. I am concerned about the amp meter though because it is only a 20 amp amp meter.
#4 | |
![]() Quote:
Charlie Stephens |
Whoa! That fuse panel from Snyder's is a little on the expensive side.
I got this 6 fuse panel off eBay for ~ $12. I like it because it has little LEDs to indicate which fuse is blown. Turn signals, Fog Lights, Spot Light, GPS/Phone charger. #3 & 6 are spares.I also have a 20a circuit breaker on the lighting/horn circuit and the 30a circuit breaker main at the starter. It is mounted on the inside of the firewall behind the gas tank using the same screws as the junction box. ![]() Last edited by Y-Blockhead; 07-25-2020 at 11:26 AM. |
#6 | |
That is very nice. Can you provide a link to it? Thx.
Jim Cannon Former MAFCA Technical Director ![]() "Spread the Joy! Have a Model A day!" |
Here ya go, Jim. Took me a while to find it. I have had this fuse box on my Town Sedan for ~4 years and I could not locate it in my purchases.
I fabbed the mount out of a flat piece of thin aluminum. I don't use the plastic cover. https://www.ebay.com/itm/12V-24V-6-W...gAAOSwrlZfBuoG Last edited by Y-Blockhead; 07-24-2020 at 08:32 PM. |
I made this after seeing an article in Model A Mag, looks like it kind of fits the era....
right by my AC compressor and Alt. LOL |
Type in "5 Gang Fuse Block" in the "Swap Meet" search box.
Perhaps this is what your looking for, I have a few left. |
This Cole-Hersee is what I used. I prefer the glass fuses. It doesn't look as modern as some of the others. Mounted it high on the driver's kick panel. Not cheap- about $25
When your wires are smoking that $25 to $50 investment may have been a good thing. The new/replacement headlight sockets are the cause of a lot of smoking wires/dead cars on the side of the road.
#13 |
#14 |
I installed this behind my drivers kick panel.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#15 | |
![]() Quote:
That looks like a nice unit, and I’m curious. How did you mount it? Did you attach it to the kick panel? Or, did you attach it to the cowl sheet metal? Did you use screws, magnets, or something else? Sent from my iPhone using Tapatalk |
#16 |
My fuse panel. Normally used on boats. It is held onto the firewall with magnets that are glued onto the panel. The hole in the firewall was there already, I just added the grommet to protect the wires.
#17 |
To use the original 12 AWG wiring the ammeter should be on a 20A branch circuit serving the battery, with the fuse panel sourced from the generator. The battery normally draws about 1A charge so the stock meter would be fine. However, you won't be able to run heavy accessories with the engine off without risking blowing the battery fuse.
