Old 10-02-2016, 09:56 AM   #1
jrvariel48
jrvariel48's Avatar
Default Snapped Conrod!
I finally had a chance to open my old motor up and here's what I found!
I'm not exactly sure how it happened. If you look close at the picture with the piston in the bore, you can see the hole it punched into the coolant passage
jrvariel48 is offline   Reply With Quote
Old 10-02-2016, 10:13 AM   #2
Kube
Kube's Avatar
Default Re: Snapped Conrod!
Yikes! What led up to this failure? Rebuilt engine?
I've never witness a rod breaking in a flatty.
What can you tell me???
Old 10-02-2016, 10:24 AM   #3
Tim Ayers
Man, that is some carnage. Did this motor have the blower on it?
Old 10-02-2016, 10:46 AM   #4
Brendan
Brendan's Avatar
that sucks! sorry!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 10-02-2016, 10:53 AM   #5
jrvariel48
jrvariel48's Avatar
I'm really not sure. I bought it as a running motor and it ran great! I was going 10 mph when it let go!
Old 10-02-2016, 10:54 AM   #6
jrvariel48
jrvariel48's Avatar
Nope, no blower, just a dual carb set up.
Old 10-02-2016, 10:55 AM   #7
jrvariel48
jrvariel48's Avatar
Originally Posted by Brendan View Post
that sucks! sorry!
Thanks Brendan! The motor's been replaced with a 1946 59L truck motor.
Old 10-02-2016, 11:41 AM   #8
Mike in AZ
Mike in AZ's Avatar
wow....have seen the pic of the con rod twisted sround the axis, but that is nasty...Mike
Mike in AZ is offline   Reply With Quote
Old 10-02-2016, 11:58 AM   #9
rotorwrench
rotorwrench's Avatar
From metal fatigue to forging flaws, it could have been from day one and got passed inspection processes or from a small blemish or inclusion that started to crack. It's a shame though. The Ford rods are stout but sh!t happens no matter how rarely.
Old 10-02-2016, 05:10 PM   #10
Charlie ny
jr,
I admit to thinking about this situation when I square off and wind my motor
to 5 grand...........I think about it but I still do it.
Charlie ny
Old 10-02-2016, 05:21 PM   #11
tubman
tubman's Avatar
I'm with "rotorwrench" on this one. When the original engine in my '51 club coupe started making a funny noise at 81K, I removed it and pulled the pan. To make a long story short, I found about a 1 inch chunk of the thrust surface of the rear main laying in the pan. I could not figure out how it could have gotten there in one piece. I've talked to a bunch of people who have some insight into this sort of thing, and the consensus is that it was a manufacturing flaw in the bearing, or and assembly error that broke that chunk out and dropped it into the pan when the car was originally built. Over the years, the reduced thrust surface wore more than it should have, thus the noise. (Yes, the noise changed when I pushed in the clutch.)
Old 10-02-2016, 05:46 PM   #12
40cpe
40cpe's Avatar
I had a Y-block break a rod like that from a bad wrist pin bushing putting unequal pressure on the rod.
Old 10-02-2016, 06:16 PM   #13
VeryTangled
VeryTangled's Avatar
Originally Posted by Charlie ny View Post
jr,
Charlie ny
I like the way you roll.
-Jeff H
Old 10-23-2016, 12:38 PM   #14
jrvariel48
jrvariel48's Avatar
I would like to reuse the Mellings oil pump I had in this motor. Can I take it apart to clean it out? I just want to make sure nothing got in there and did any damage.
Is there any gaskets that need to be replaced?
Thank you,
Joe
Old 10-23-2016, 01:54 PM   #15
Ronnie
Ronnie's Avatar
Can easily be taken apart.
R
Ronnie is offline   Reply With Quote
Old 10-23-2016, 02:05 PM   #16
flatjack9
flatjack9's Avatar
There is a thin gasket between the bottom plate and the housing.
Old 10-24-2016, 07:04 PM   #17
jrvariel48
jrvariel48's Avatar
Thanks guys! I'll give it a try
Old 10-24-2016, 09:06 PM   #18
Flathead
Flathead's Avatar
I don't know the history on your motor, but the top end of that rod where it broke, looks very rust pitted. It looks like it was rusty and then maybe bead blasted, a good rust pit can make a weak spot that will crack under stress. These rods are normally quite strong and not brittle.
Flathead is offline   Reply With Quote
Old 10-24-2016, 09:53 PM   #19
Kurt in NJ
Kurt in NJ's Avatar
I just went back and looked again and I will agree that it looks like that rod was very rusty at one time
Old 10-25-2016, 03:57 AM   #20
jrvariel48
jrvariel48's Avatar
interesting! I don't know the history of the motor. I bought it as a running motor and installed it.
