Old 12-25-2012, 02:52 AM   #1
paul guy
Default pinging and knocking
I have done nearly 4000 miles in my 30 mod Town Sedan on a rebuilt motor and it goes great I am really impressed but I cant seem to stop the pinging ang knocking when I want more power like going up a steep hill and I always have to back of. Any suggestions I run a 6.1 head, electronic ignition, weber carby, touring cam, lightened flywheel, slipper bearings. I use high octane fuel I have it retarded about 8 degrees. The motor does not run hot any ideas thanks paul from down under
paul guy is offline   Reply With Quote
Old 12-25-2012, 03:12 AM   #2
H. L. Chauvin
Default Re: pinging and knocking
Engine pinging while going up a steep hill is usually a result of advanced timing.
Retarded 8 degrees -- retarded 8 degrees from what?
It would help to know how many degrees are you before top dead center, (BTDC) when climbing a hill.
Merry Christmas
H. L. Chauvin is offline   Reply With Quote
Old 12-25-2012, 04:03 AM   #3
paul guy
thanks for your advice. I retarded the timing 8 degrees from TDC at idle approx 450 rpm. Because I have fitted a electronic dizzy I dont really know how advanced the timing is when it starts to ping and knock I hope this helps thanks paul
Old 12-25-2012, 06:34 AM   #4
Patrick L.
Patrick L.'s Avatar
It sounds like you have and are using a timing light. It would be nice to see how much and fast the advance you are getting. It sounds as if you're getting too much advance too quickly. What type of advance system does this distributor use? If it uses springs and weights, then it can be adjusted to limit and slow the amount of advance by changing to heavier springs/weights.
Old 12-25-2012, 11:41 AM   #5
Marco Tahtaras
Marco Tahtaras's Avatar
Do you have anyone around with a cheap tach/dwell tester? You need to test and log the timing at various engine speeds to determine the advance curve (or have the distributor tested). It may not be suitable for your application. In the meantime it sounds like you need to retard the timing a bit.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-25-2012, 02:47 PM   #6
paul guy
Thanks for your ideas guys it is an fs dizzy I will check it out more and let you know thanks Paul from down under
Old 12-25-2012, 03:17 PM   #7
Jim/GA
Jim/GA's Avatar
If this is the FS distributor with the weights and auto advance, they can get you springs/weights for the 6.0 head and you will not have a problem. We initially thought you were advancing with spark lever on the column. You really want the initial timing to be close to zero at TDC, not 8 degrees retarded. FSI can fix you up.
Jim Cannon
"Spread the Joy! Have a Model A day!"
Old 12-25-2012, 05:38 PM   #8
paul guy
Thanks Jim I will contact FSI they have been very helpful in the past. Regards Paul from down under
Old 12-25-2012, 09:41 PM   #9
Marco Tahtaras
Regardless of what I'm told I'm purchasing I would test and log the advance curve. Also, If the centrifugal advance is designed to be timed at TDC at idle then it will have insufficient advance through the low and mid ranges.
Old 12-26-2012, 02:10 PM   #10
bill44
bill44's Avatar
I had the same problem with a 5.5 head. I sent the unit back to FS and had them reduce the advance to 22*. That seems to have solved the problem. I won't know for sure until Spring.
bill44 is offline   Reply With Quote
Old 12-28-2012, 05:55 AM   #11
paul guy
Thanks every one for your help, I think I have solved the problem after some advise from fs ignitions I checked TDC with number 1 spark plug removed and found that the indentation in my fibre timing gear does not exactly correspond with number 1 piston being TDC regards paul from down under
