Should the spring pre-load screw be on the drag ling of my 52 Merc?
I know on my 49 truck you tighten the screw all the way down fully compressing the spring and then back off to the first cotter pin hole, that's per the service manual.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
I don't have a service manual and PO did not key it.. A bit loose you might say. Thanks again |
