Old 10-05-2012, 02:23 PM   #1
lance leblanc
lance leblanc's Avatar
Default Riddle my rivets!
As a new comer to Ford Barn I want to Thank all the folks who share their knowlegde and experience on these forums.
"Without it I believe I would have never garnered the courage to begin the frame off restoration of my father-in-laws '29 Tudor".
So to my question, I wish to replace the rusted cowl panels that are below the fuel tank and are riveted to the firewall.
Where do I begin?
How much do I need to be concerned with the stability and alinement of the firewall? (will it take care of itself)
What rivet tools are recommended, do I need a air tool?
What size rivets?
Should I be losing sleep at night of this?
Lance
lance leblanc is offline   Reply With Quote
Old 10-05-2012, 04:07 PM   #2
Carter
Default Re: Riddle my rivets!
If I am not mistaken, the cowl panels are spot welded to the firewall. The only rivets would be the 3 on each side under the bottom where that flange rivets to the subframe connector.
The cowl lacing rivets would go along there, but they don't hold the panels together.
Carter is offline   Reply With Quote
Old 10-05-2012, 04:16 PM   #3
wrndln
If the cowl isn't that badly rusted out, I would simply install a patch in the rusted area. It is that hard to do, much easier, I think, than trying to install a repro panel that may or may NOT fit correctly - note the emphasis on NOT. I have installed several cowl patches and it is not that hard.
Rusty Nelson
Old 10-08-2012, 02:59 PM   #4
lance leblanc
The panel is only rusted the botton 4 inches so I have concedered a patch, but with out the use of a welder and wanting to do as much myself as posible,
the entire panel seemed the way to go. However if these are spot welds that I am looking at and not rivets then that changes things.
Old 10-08-2012, 07:22 PM   #5
Elcastor
Elcastor's Avatar
Take it to a guy that can weld in a replacement piece of sheet metal. It is a job for a welder, and it should not cost too much to get it done right. Prefabricated patch panels just do not seem to work that well. (This is what I recommend anyway, others may disagree!)
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 10-08-2012, 07:25 PM   #6
Mitch//pa
just get the bottom patch panels thats a common spot for rust out.
