Old 07-23-2012, 07:34 PM   #1
Bassman/NZ
Bassman/NZ's Avatar
Default Tekkernickel question....
Anyone know if the pinion in a 3.78 rear (9-34) is the same as the pinion in a 4.11 (9-37). I wondered if maybe the teeth are smaller to accomodate the extra ring teeth? Just curious.
Marty.
Bassman/NZ is offline   Reply With Quote
Old 07-23-2012, 08:41 PM   #2
Pete
Default Re: Tekkernickel question....
Not the same pitch diameter. They won't interchange.
Old 07-23-2012, 08:54 PM   #3
ford38v8
ford38v8's Avatar
That's an interesting question. Thinking of the variables of tooth sizes and gear diameters, the answer may be different for different ratios. One thing i can tell you is that they are machined in matching sets, with etched serial numbers.
Alan
Old 07-23-2012, 09:24 PM   #4
Bassman/NZ
Bassman/NZ's Avatar
Ah... that's what I suspected, and I suppose is quite logical when I think about it.
Old 07-23-2012, 10:10 PM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I'm sure thay were a matched set when new nut I remember early 50 when I was a young teenager we would pull one axel housing and pull the axels and ring gear, put another ring gear on (differant ratio) put it back together and drive the s--t out of it. They always worked fine. Walt
Old 07-23-2012, 10:17 PM   #6
Bassman/NZ
Bassman/NZ's Avatar
Hahaha.... I love stories like this.
Old 07-23-2012, 10:58 PM   #7
41ford1
41ford1's Avatar
Even in the 60s, been there done that. The gears may might sing a little bit. So what!! At least it went down the road.
41ford1 is offline   Reply With Quote
Old 07-23-2012, 11:21 PM   #8
OldDad
OldDad's Avatar
Hopefully none of those rear ends have made it out to the west coast . . . hmm
OldDad is offline   Reply With Quote
Old 07-23-2012, 11:24 PM   #9
JM 35 Sedan
JM 35 Sedan's Avatar
I've heard of mixing ring and pinions from matched sets of the same ratio but not too many success stories of mixing those parts from different ratios and actually driving very far with those mismatched gear ratios
Also, I question if Ford actually 'machined matched gear sets' persa...what they most likely did was pre lap grind pre-machined ring and pinion gears together in some type of fixture to better match their tooth profile and then mark them as a matched set for assembly in the same rear. At least this is how the company I worked for matched gear sets in products that had critical specs for allowable gear noise.
John
Old 07-24-2012, 12:05 AM   #10
Pete
They made pinions on one machine (several actually). They made ring gears on another set of machines. They were "matched" insofar as a set was marked as a set when installed. This was for reference later if service was needed.
They were not lapped but merely adjusted for proper clearances when installed. Machining tolerances were every bit as good as they are today.
Old 07-24-2012, 07:43 AM   #11
V12Bill
V12Bill's Avatar
The Way of the Zephyr (LZOC newsletter) published a factory photo of a ring and pinion being lapped in on a machine. Maybe only the Lincoln had this luxury .
V12Bill is offline   Reply With Quote
Old 07-24-2012, 11:38 AM   #12
bobH
OK, I never posted the following... One of my heaps has a ring gear from one junk pile, and a pinion from another junk pile. The only care I took... Both are Ford script, and I was VERY careful with assembly, meaning NO short-cuts, everything double (or triple) checked, including final pattern. I've got several thousand miles on it, no noise, no bad habits, no problems. Matching etched numbers... No. And, in response to a previous post, I am from Pasadena. The pinion was ground (for late-early mod) by an excellent flathead guy in Monrovia.
ps... I wondered about the 9-34 vs 9-37 pinion, too. I compared my junk pinion to a known 'good' one that a friend had, and I've forgotten what I learned from that - so no help there. Then, I realized that I knew where my junk pinion came from, and I knew it was originally a 9-34.
bobH is offline   Reply With Quote
Old 07-25-2012, 01:39 AM   #13
OldDad
OldDad's Avatar
Hah, Bob, I was joking! And thanks again for those pages out of the Green Bible you sent me!
Old 07-25-2012, 02:08 AM   #14
Manuel
Bassman,
What is Tekkernickel?
Thanks
Manuel in Oz
Manuel is offline   Reply With Quote
Old 07-25-2012, 03:23 AM   #15
Bassman/NZ
Bassman/NZ's Avatar
Originally Posted by Manuel View Post
Bassman,
Thanks
Manuel in Oz
It's a new process for replating original Model A radiator shells.
Old 07-25-2012, 03:27 AM   #16
52merc
52merc's Avatar
you guys over the ditch dont know what a TEKKERNICKEL IS ????????????!!!!!!! HA HA COULDNT RESIST MATE,,,,,,,,,,,
52merc is offline   Reply With Quote
