Old 07-09-2012, 08:42 AM   #1
Raven
Default Float-a-motor...
I currently have the radiator and cylinder head off of my '31 roadster. When I purchased the car the owner said the he couldn't get the hand crank to fit in the pulley...it wouldn't line up. Now that I have the front portion of the car off I can see that the engine is sitting up on the front float-a-motor mount at such a height that the hand crank wouldn't mesh with the pulley. Tightening down on the mount helps with the crank/pulley alignment but takes pretty much all the float-a-motor spring suspension out of play. This doesn't seem right as the engine should be free to "float" on the mount and not be bound tightly to it. Am I missing something? Is there an alignment or adjustment on the back motor mounts that could cause the engine to be cocked at an angle so as to not allow alignment between the hand crank and pulley? I want this to be right before I start putting the car back together...thanks
Raven is offline   Reply With Quote
Old 07-09-2012, 09:02 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Float-a-motor...
Are thew rear mounts original or changed to the floaters??
Paul in CT
Old 07-09-2012, 09:04 AM   #3
Ray in La Mesa
I have Float-a-motors on my pickup. The side and rear mounts are all I use, the front is stock Model A and everything lines up perfectly.
Ray in La Mesa is offline   Reply With Quote
Old 07-09-2012, 09:16 AM   #4
MikeK
MikeK's Avatar
Bent frame? Fairly common find when you buy an A.
MikeK is offline   Reply With Quote
Old 07-09-2012, 09:51 AM   #5
Ron Lowe
I did the same thing as Ray said and got the same results, everything lines up fine. That hand crank is real handy when you get ready to time your car. Ron
Ron Lowe is offline   Reply With Quote
Old 07-09-2012, 10:00 AM   #6
Mitch//pa
i have had a few of these and what i found was the mounts that bolt to the flywheel housing can be turned upside down... try flipping them over and that lowers the front of the motor..apparently they are installed backwards alot of times. there is an up and down side to them
looking straight down on the mount with it sitting on a flat surface as in the pic the bolts are uneven. the top of the mount is shown here with the more visible bolt...
Old 07-09-2012, 01:31 PM   #7
Raven
Thanks for the answers...this is not my first A but the first with float-a-motors...
Old 07-09-2012, 05:09 PM   #8
Herb Concord Ca
I have rear float-a-motor mounts and stock front mounts on both my A's and the crank lines up on both.
Herb Concord Ca is offline   Reply With Quote
Old 07-10-2012, 08:48 PM   #9
green30coupe
green30coupe's Avatar
I have the same setup as Ray and have no alignment problem.
Ed
green30coupe is offline   Reply With Quote
