Old 01-15-2014, 01:26 PM   #1
37coop
37coop's Avatar
Default wiring question on my 51 .f.1truck
hi guys , I,m rewiring my truck wire by wire ,mostly it has gone smoothly but of course very time consuming . electrics is not my thing and I find some of it confusing ........my questions are , undoing the nuts to release the wires on the circuit breaker under the dash a small bolt holding the wire broke,i,v taken out the unit and soldered a connector to the broken bolt , the query I,v got is by doing this I,v had to apply heat and I,m wondering if the heat would make the unit disconnect,if so how would it reconnect ,on modern breakers you push a button to get power back,how would it work on this , its the original unit . also on my truck , above the solenoid to the corner is a relay ,when I took the outer wiring cover off some of the wiring disintergrated and I cant follow where one of the wires went , the relay is not on the wiring diagram I,v got ,I,m assuming it goes to live but not sure , sorry if my description is confusing ,any help would be appreciated , thanks jim.
37coop is offline   Reply With Quote
Old 01-15-2014, 02:53 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: wiring question on my 51 .f.1truck
Circuit breakers for the old Fords were bi-metalic strips that were heat sensitive inside the little rectangular enclosure. It gets hot & opens the circuit then cools down and closes the circuit. These breakers were used clear up to modern times in large trucks here in the USA so new ones are just a truck stop away but parts stores carry them too.
The common relays for Ford vehicles are starter and horn. The horn relay has B (battery), H (horn), and S (switch) terminals. Other relays would be accessory specific like for an overdrive system.
Old 01-15-2014, 04:35 PM   #3
37coop
37coop's Avatar
thanks rotor,i feel better for that , jim.
