Old 04-14-2012, 03:37 PM   #1
rusty12
Default Pinto Engine Conversion Reversal?
I am considering buying this 1928 roadster. It is an original, all steel car, NOT one of the Shay reproductions. The car currently has a modern four cylinder (Pinto?) engine and transmission. The owner told me there was a conversion kit made awhile back to adapt this engine into a stock A. I have not yet seen the car in person (I'll probably be buying it sight-unseen) and was wondering if anyone here knew about these kits and what it took to install one. Of course, if I buy the car I want to put a stock Model A engine and transmission back into it and was wondering what problems I might incur? ( I realize the paint and upholstery are far less than correct, but, hey, the price is right!)Thanks in advance.
rusty12 is offline   Reply With Quote
Old 04-14-2012, 03:48 PM   #2
anteek
Default Re: Pinto Engine Conversion Reversal?
That's not a pinto engine,it's a 153 Chevy 4 cylinder. It may be bolted to a flathead v-8 transmission without a driveshaft modification. Good luck.
anteek is offline   Reply With Quote
Old 04-14-2012, 04:01 PM   #3
Richard Wilson
Richard Wilson's Avatar
It doesn't look like anythings been cut up. May just be able to find the needed original parts and swap the engine and trans out. I bet the rear end is changed from original also. The shifter ball looks like it is diagramed for an automatic transmission. Also only gas pedal and brake pedal in the floor so I would bet automatic. To do a good job on putting the car back to original you will need to pull the body and fenders off to gain full access to the frame.
Richard Wilson is offline   Reply With Quote
Old 04-14-2012, 04:56 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Personally, if it's runable and the price was right, I'd buy it & drive it, I might LIKE it as is! We always risk gettin' into a 9 year burn-out project just to make it PROPER!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-14-2012, 05:01 PM   #5
PetesPonies
PetesPonies's Avatar
I agree, it would be a nice driver as is.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 04-14-2012, 05:07 PM   #6
Keith True
Keith True's Avatar
It's all nuts and bolts,an easy changeover.That is a nice setup for an A if you want to go that route.I would be willing to bet there will be a lot of people interested in that setup once you take it out.The marine version of that engine is 120 HP.I looked at one of those swaps years ago,the main thing I remember was they had moved the radiator lower outlet to the opposite side,and they were running an open driveshaft.I still think plenty of people will want all those parts.
Old 04-14-2012, 06:28 PM   #7
1931 flamingo
1931 flamingo's Avatar
Ditto with what keith said. Where are you located??
Paul in CT
Old 04-14-2012, 06:43 PM   #8
Jim Parker Toronto
Jim Parker Toronto's Avatar
Looks like it was a nice conversion, I'd run it till it broke, and then change it back!
Jim Parker Toronto is offline   Reply With Quote
Old 04-14-2012, 07:23 PM   #9
rusty12
Hopefully I'll have some better photos of the underneath to see if it has the right rear end if there are any other alterations that aren't bolt on and off. The late model engine and automatic trans bugs me and I don't think I could live with it, so it will become available once removed. I am in Michigan.
Old 04-14-2012, 07:49 PM   #10
Charlie Stephens
Instead of making it available after it is removed I would suggest building up a model A engine/trans/rear end on the side and selling the engine/trans/rear end before you remove it from the car so the person can see it run. I have the same engine (it is definitely a Chevy II engine and not a pinto) in a '32 roadster with a '39 trans and original rear end. Although slightly different from what you are looking at it went in without cutting anything so I could return the car to stock later.
Charlie Stephens
Old 04-14-2012, 10:10 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with the guys. At least drive it while you take your time gathering up the other parts needed to change it out. By that time you might like it as is.
Old 04-14-2012, 10:51 PM   #12
hardtimes
hardtimes's Avatar
Last edited by hardtimes; 04-15-2012 at 02:02 PM. Reason: ....duplicate for some reason?
Old 04-14-2012, 10:55 PM   #13
hardtimes
hardtimes's Avatar
[QUOTE=
Appears someone did a nice sanitary job. I can understand where your mind is in this situation. However, what I would do is....get an appropriate frame and build it with engine/trans setup that you prefer. Then move your body/etc to that new restored frame and sell off what you don't want. That way, you can drive this concoction and have a ride. Who knows...you may even get to like what you've bought!
Old 04-14-2012, 11:09 PM   #14
newshirt
newshirt's Avatar
Rusty,
The guys you've heard from are solid individuals on this board. Their opinions are probably spot-on. I'm a relative newbie, so take my silly opinions with caution...
This looks like disaster to me. A money pit.
After you've replaced the motor, tranny, diff, and what-all-else, you've spent more than comparable cars you can find on mafca.com, ebay, or elsewhere.
But on the other hand, if you're a competent restorer with a bankroll, this could be a fun frame-up project!
Ray White
newshirt is offline   Reply With Quote
Old 04-15-2012, 01:52 AM   #15
mach0415
mach0415's Avatar
The funny thing is that to those that don't know squat about A's, that engine area looks "vintage." Though I am a purist, of sorts, it actually does look kinda neat and tidy sitting in there, not all hacked and rigged to pieces - even if its a bow tie. Henry would be rolling over in his grave if he saw that, hehe.
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 04-15-2012, 09:00 AM   #16
jimvette59
jimvette59's Avatar
PAINT IT BLACK !!!! and drive it until you have all the parts to put it back to original If you need to, I am sure somebody would love to have that setup. JMHO.
jimvette59 is offline   Reply With Quote
Old 04-15-2012, 09:13 AM   #17
MrTube
MrTube's Avatar
If it was me, I'd buy it and drive it as is. I would also keep it as is even after any failures as I have to think, after driving it with 100+HP I wouldn't want to go back to 40.
I would buy that one and then look for a restoration project, afterall whats wrong with having two "A"s? A fun one and an original?
MrTube is offline   Reply With Quote
Old 04-15-2012, 09:48 AM   #18
Ken B
Ken B's Avatar
I suppose it all depends on the price you can get it for. Then consider what your plans are for it. Does it also have hydraulic brakes to stop the 100 HP? If the price it right, buy it and drive it!!!!
Ken B is offline   Reply With Quote
Old 04-15-2012, 10:07 AM   #19
Rex_A_Lott
Leave it alone, let somebody buy it who will appreciate it the way it is, and buy yourself a nice car with a stock running gear, which is what you want anyway.
Rex_A_Lott is offline   Reply With Quote
Old 04-15-2012, 10:15 AM   #20
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I'd keep it the way it is (maybe a paint job) if it were me. Those Chevy fours are good engines and it looks like a good installation and pretty unique. Keep the body and wheels stock and go with it if you can get it at a reasonable price.
Barry B./ Ma. is offline   Reply With Quote
