Old 11-08-2011, 08:46 PM   #1
Huckster
Huckster's Avatar
Default KRW Question
I have a KRW V130 .does anyone know what it was used for?
Huckster is offline   Reply With Quote
Old 11-08-2011, 09:25 PM   #2
andyg
andyg's Avatar
Default Re: KRW Question
Valve spring assembly / disassembly tool. You put the valve, spring, guide and shims(if needed) and compress it so you can put the keepers on the end of the valve steem and thus have complete value setup to install in your flathead ford.
At least I think that's what you have. Someone else will say for sure.
andyg is offline   Reply With Quote
Old 11-09-2011, 05:10 AM   #3
Huckster
Huckster's Avatar
Thanks for the info. do you know what era it was used t,a,V8? Thanks
Old 11-09-2011, 06:22 AM   #4
James Rogers
James Rogers's Avatar
The tool was used for the flathead Ford V8. The valve assembly is put together then inserted into the engine and held in place with a horseshoe keeper. I might be interested in it if you want to sell it.
James Rogers is offline   Reply With Quote
Old 11-09-2011, 04:57 PM   #5
Huckster
Huckster's Avatar
thanks for the info.let me think about it i have no idea what the value is on something like this is.
Dont get too excited.
Old 04-08-2012, 01:50 PM   #6
valsvittles
Do you still have the KRW V130 tool? I might be interested in buying it if for sale.
valsvittles is offline   Reply With Quote
Old 04-08-2012, 01:54 PM   #7
Russ/40
Russ/40's Avatar
I'm interested in it as well. Want to do a silent auction?
