Old 03-23-2012, 11:56 AM   #1
Don29
Default Paint
looking for info on painting the service brake and emergency brake cross shaft assembly cant seem to locate the info in the MARC judging standards
Don29 is offline   Reply With Quote
Old 03-23-2012, 01:06 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Paint
Both assemblies were initially dipped in enamel (gloss finish) assembled and installed, --or visa-versa depending on the year of the e-brake shaft. Areas of paint that were damaged (i.e.: installing the arm or peening the pin) were likely sprayed with pyroxilyn (semi-gloss) as a corrosion deterrant.
As far as the Judging Stds. or adjudication is concerned, all that is required of the frame or the assembly is for it "...to be painted Black, and not rubbed out". It is my opinion the reason it is written this way in the J/S is to give leniency towards the restorer in this area. More of this is covered in the Faint & Refinish Guide however MARC does not recognize nor want that book to be used in adjudication.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
