have 59AB unstuck and spining free,but no compression,i put oil in clyinders and have 50 lbs compression,rings must be stuck to piston,is there anything i could try to free them up? before i pull engine? al
I do not the full story of your engine. Does it run? I had a freshly built engine with very low compression. A professional builder told me not to worry, it would be fine. And it was. Try and start it and see how it runs.
Some days you just have to bit the bullet. First stuck,now no compression. If you'er just going around the block ,thats one thing,but if you are looking for a dependable motor ,open it up and do it right. Sounds like a really tired motor. If money is a issue,we should all be looking at a different hobby. JMO
[QUO[/QUOTE]no matter where you are,or where you're at, there you are... ![]() |
this motor is not tired , its be sitting a long time had head off and clyinder looks fine no ridge,no rust very little carbon,the rings we stuck to cly wall,pulled pan rod bearings look new,i think the motor was rebuilt ,money is not an issue looks like you have a street rod an ugly one at that
#5 | |
![]() Quote:
From your description, it seems to be a low mileage engine with no cylinder wear...while it's apart, why not just scuff hone the walls (assuming here that measurement verifies them as good and straight) and replace the rings only? I think too many people get into complete rebuilds on solid engines and replace too many good parts...measure, measure, measure, and if measurement confirms the engine as unworn just replace potential trouble like those rings. Rings are cheap and have the potential to make your life miserable if no good. |
#7 | |
![]() Quote:
I dig coal, which provides motivation for EVs. |
Put some MMO with a dash of acetone in each cylinder and put the plugs back in. Let it sit for a day, then recheck.
I agree with Russ/40 ... it is worth a try!
Marvel Mystery Oil added to the oil (replace a quart) when you try and start it up, will help kinda free everything up. I did as Russ said above, with the old engine i'm messing with. Put some in the cylinders for a few days, put it in the oil and gas. Ran it for maybe 20-30 minutes total. Drained and put good oil with MMO and ran for a couple hours total. Then another oil change with 20-50; Made a big difference with the compression.
We carry: Amsoil Synthetic Lubrication products |
Rislone makes a produt called "ring free" it was used a lot in the old days for that purpose also, a qt. added to oil.. I like the MMO
thanks guys i put MMO w/actone let it sit a day and give it a shot...al
#13 |
if he had the rod caps off, why not pull the pistons and see what's what??...like you say, maybe replace the rings and see how it runs....could break a ring trying to run it now and cause some major damage to cylinder??....just thots...Mike
#14 | |
![]() Quote:
I'll be starting to plan my trip to Utah soon. Depending on which route I take out and back, I may get close to your neck of the woods. I would like to cruise around your area some and see what's going on ![]()
