Hello,
There is a guy selling over drive systems for a stock model A on ebay for about $1650.00. You have to send him a good tube. Anyone out there using one? Are they any good? Any feedback? Thanks, Marty |
Is this the unit you are referring to??????
AL in NY |
If it looks like the one Al in NY's photo. That's a LayCock de Normanville overdrive, use in European cars before 5-speeds came into use.
It's a good unit, and IMHO it's the best way to go! I have one, it's now in it's second model A, have used it for 10 years, currently in my S/W Town sedan. It's operated by a toggle switch, no mechnical linkage to take up floor space! Price seems a little high, but who knows. Regards herb |
i have a volvo unit, and think its the greatest thing ever....
easily as important as the type of overdrive, is the engineering behind the adaption and its execution. I've seen these with really crappy welding and poorly designed reinforcement, so that the torque tube sags and the drive line fails. I've also seen them done excellently from Rich Little.
Also, since these units are from used vehicles, is the OD rebuilt? What is the name of the seller and builder? I cannot tell any of that from this description. caveat emptor |
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
I agree with Pat talk to someone who has one of the units they made, the Laycock is good, but the welding and fabrication has to be good too.
My friend just bought the same LayCock de Normanville overdrive to install in his 1929 Stutz. If I was going to install an overdrive that's the unit I'd like to use also.
My friend with the Stutz bought a set of 3.27 ring and pinion gears from Bert's for his 31 widebed, and I can't wait to drive it with them. Still waiting on the bodyman to finish painting the box for his widebed. The painter has only had it for 10 years! ![]() |
Tom,
The painter must be using the really slow drying paint! LOL |
Hi i think your reffering to my Overdrives on ebay,im the guy building them. GLENN
Yes i rebuild them and i have a dyno setup to test them. GLENN
Hello,
Yes, the one in the photo is the one I am refering to. Looks like the maker has joined in. I had some bad experiences on ebay and I am always a little "uneasy" about getting certain things on there (esp when it cost a good bit of money). Marty |
#13 |
yes, they are volvo,yes the tubes are machined before they are tig welded,No need to balance.Yes 6 month unlimited mileage warranty.
Ive got all the parts i need to rebuild them. GLENN ![]() |
#14 |
Well ive been rebuilding GV units for years. and For the Hot rod guys with 800hp+, ive had alot of guys ask me to build custom one offs.So now
its time to help out the guys with the torque tubes.Ive got a web site but im not sure i can post it here on the form. GLENN ![]() |
#15 |
I have a Laycock D'Normanville in my sedan, and it is my preferred OD. Maximum OD, could you show some detailed photos of the connection to the torque tube, please? I don't think there is a rule against posting the website, My guess is its here:
http://www.maximum--overdrive.com/products.html |
#16 |
Pat
yes thats its the site. actually your in santa cruz,im very close,im in Aromas.but to answer your question,the first one i used a splined coupler that i had made,but now im using a coupler with a 1 inch blind hole 1/4 keyway and a 3/8 cross drilled hole and a hardened dowel pin.I will have to find the pictures. |
#17 |
At that price why not go with the Mitchell for a few $$ more? It's new, it's fully mechanical, and parts/rebuild are available!
#18 |
yeap! a few hudred more.and when i rebuild them there like new .theres pro`s and cons for both. one of the best features about the Laycock is full power shifts you dont have to back off the gas at all
#19 |
I usually push in the clutch when I shift mine. Is that not needed?
#20 |
it shifts witha toggle switch, feels like an automatic trans when it shifts. parts are avail, very common at local yards, i found five of them in one location. and cheaper. thats why.
