The brake lever in one brake rocks a bit in its bushings. Any guidance on how loose the brake lever can be in the bushings before the bushings should be replaced? I haven't found anything in the Service Bulletins nor in Les Andrews book. I'm tempted to just replace them as I have the backing plates off the car - that way I'll know they're okay.
Second question.... is there a way to remove the rear wheel backing plates from the car with the radius rods still in place? It's academic now as I have removed them after losing this fight with the first backing plate unit! But I am curious as Les Andrews doesn't mention the radius rods nor how one "...lifts the backing plate off the car for further disassembly...". ![]() |
I have always removed the radius rods since it seems like a Chinese torture drill to try to get the plates out with the rods still attached.
I would suggest that you replace the bushings and both levers since you have the backing plate off. If you don't replace the emergency levers, consider drilling them for a grease fitting. Gar Williams |
Gar, good idea re: grease fitting on the e-brake levers. My sense is to replace anything that can wear as other indications are that these brakes haven't been taken apart in a LONG time.
Its easy to remove rear backing plates if you snap the service brake lever forward till its horizontal,then it can be wiggled out.
I'm with Areocraft on this one. You can wiggle them off, but they have to back on and that ain't fun! It's easy enough to undo one more bolt, and then put it back in.
Thanks for the ideas. I must say that I tried every possible combination of the service lever and emergency lever positions - no joy. Perhaps if I had removed the emergency brake lever.....
I'm planning to replace the bushings and shafts - it'll be a while before I'm back in there, and there's no point to not replacing them. I now have all 4 brake units out of the car. All of the tracks are worn - plan to weld them up and grind down to spec. Will have the backing plates all sand blasted before that - there's a local fellow who takes a lot of care and can be relied on to clean only the surfaces I want done. |
I would not bother welding up the tracks. For the same money or less you can purchase new ones and have them installed. Then you know they are correct! At the same time you can add a grease fitting to the E-brake lever!
