Old 12-25-2011, 01:14 PM   #1
LarryPhillips
Default 1950 Ford F-1 Pickup
Can anyone help with an answer:
I am restoring a 1950 Ford F-1.
The winshield opening has metal tabs extendig from the opening edge, two on top and two on bottom. They are a little over an inch long and protrude forward about 1/8".
What are these tabs for?
Thanks for any help I can get.
Larry
Larry Phillips
5201 Hamilton Road
Columbus, Georgia 31904
Office 706-324-7758
Cell 706-570-2677
[email protected]
LarryPhillips is offline   Reply With Quote
Old 12-25-2011, 05:17 PM   #2
Barry-ct
Barry-ct's Avatar
Default Re: 1950 Ford F-1 Pickup
They help position the glass in place. They have to be bent down when you install a new weatherstrip and glass. You then bend them back up. They are a pain in the neck to bend back up after a new w/strip is in place. I just went thru this recently when I installed all new glass in my 50 F-1. The back glass is the worst one to do.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 12-25-2011, 09:02 PM   #3
Mountaindoc
Mountaindoc's Avatar
Most of the guys who have done this aren't very broken hearted if those tabs get broken off. You will be okay without them.
Mountaindoc is offline   Reply With Quote
Old 12-26-2011, 09:31 PM   #4
pauldeborr
pauldeborr's Avatar
I had the same issue. I didn't know what they were for. My freind who worked for a glass company didn't even know what they were for. I just tried to bend them up as much as I could without cracking the glass after the seal was in place. They still kinda stick out but only noticable if you know they are there.
I guess if I pull the windsheild out again in the future I will just cut them off and not worry about it.
pauldeborr is offline   Reply With Quote
