Old 06-05-2011, 12:47 PM   #1
wrndln
Default Painting inside brake drums
I am starting to paint my new cast iron brake drums. I would like to get an opinion on whether to paint the inside of the drum (non-brake shoe area only). I would think it would keep the drums from rusting, but would the paint cause any harmful effects?
Old 06-05-2011, 01:32 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Painting inside brake drums
I paint them on the inside, but make sure NO overspray gets on the brake shoe contact area. Even a light dusting of overspray makes them very grabby.
Old 06-05-2011, 01:34 PM   #3
Ron in Quincy
Ron in Quincy's Avatar
I believe its a good idea; have always painted mine over the years and have not experienced any problem. Just my opinion !!!!!!
Ron
Ron in Quincy is offline   Reply With Quote
Old 06-05-2011, 01:56 PM   #4
Mike
Mike's Avatar
I have also painted my brake drums, appling the tape is a real pain in the ???
Brattons has high temp gloss black that is real good
mike
Mike is offline   Reply With Quote
Old 06-05-2011, 02:42 PM   #5
Roger V
Roger V's Avatar
Ditto to the others.
Roger V is offline   Reply With Quote
Old 06-05-2011, 04:27 PM   #6
CWPASADENA
CWPASADENA's Avatar
I also agree!!!!
I think it is a good idea.
I made strips of heavy paper (I think from an old calander) that I used to mask the inside of the drum. A little tape would hold them in place. I used Black hi-temp Brake Drum Paint thet I got from Eastwood. Immediately after painting, I would remove the strips and wipe the friction surface with lacquer Thinner to remove any residue.
Chris
CWPASADENA is offline   Reply With Quote
Old 06-05-2011, 05:15 PM   #7
glenn in camino
glenn in camino's Avatar
I've always painted mine with rustoleum. Some have been painted for over 30,000 miles and still look great.
Old 06-05-2011, 07:35 PM   #8
Reds34
I've got a trick for painting the insides of the drum. Take a thin coat of grease and put it where you don't want the paint. The paint won't stick to the grease, and you can take some lacquer thinner to it when you're done. It also works on decals you don't want to paint.
Red
Reds34 is offline   Reply With Quote
Old 06-05-2011, 08:27 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Red
In the mid '40's, when painting the Model A, Chief and I applied heavy grease very carefully to the windows with a wide putty knife, greased all the chrome, and sprayed away!! Grease was removed from the windows with a razor blade scraper, then wiped with a damp solvent rag.
"THE ASSISTANT GURU OF STUFF"
Old 06-07-2011, 01:54 PM   #10
jbird
Agree with everyone, I use PPG DP90 epoxy, mixed 1:1 just mix what you need, mask the areas you don't want painted, and apply with a cheap brush, it flashes pretty quick so you can apply 2 coats. I use DP epoxy (black) on the chassis, u can top coat with any product you like. Just wipe down the brake face area with prep-sol or other solvent to clean off any oils and contaminates.
jbird is offline   Reply With Quote
Old 06-07-2011, 09:15 PM   #11
Bruce,Upstate NY
I'd use the DP90LF and just leave it. No overcoat needed.
Bruce,Upstate NY is offline   Reply With Quote
Old 06-07-2011, 11:23 PM   #12
Arlyn Bieber
No need to mask if you paint the inside of the drum before it is machined.
Arlyn Bieber is offline   Reply With Quote
