Old 08-10-2025, 04:24 PM   #1
3twinridges
3twinridges's Avatar
Default Fitting rings question
Fitting the rings in #1 using grant rings on a fresh honed 8BA cylinder. Got the first oil ring fit. When I got to the 2nd oil ring it has a spring inside with directions on joint placement. Tried to compress it and it’s a tight spring! I don’t remember that in the last Hastings rings I used? Is it needed?
JB
3twinridges is offline   Reply With Quote
