Old 08-11-2025, 03:13 PM   #1
kurt v
Default door panel hard cardboard
where can i find the hard board for the door panel ?
kurt v is offline   Reply With Quote
Old 08-11-2025, 03:38 PM   #2
51504bat
51504bat's Avatar
Default Re: door panel hard cardboard
This video mentions using 1/8" plastic material (ABS?) which is available from any plastic supply house or ebay.
https://www.bing.com/videos/rivervie...E45E&FORM=VIRE
Edit: Video indicates the 1/8" material is PVC
Old 08-11-2025, 06:32 PM   #3
Tony, NY
Here is a waterproof panel board.
https://www.automotiveinteriors.com/...ctCode=cowl-dp
Tony, NY is offline   Reply With Quote
Old 08-11-2025, 07:08 PM   #4
ActionYobbo
ActionYobbo's Avatar
You can get project board at hobby lobby if you like to be more original. I used 3mm lauan which is thin plywood and can be cut with a utility knife. Seal it with water based polycrylic and then upholster how you like. Lauan is flexible so it can be curved or formed a reasonable amount and can be cut, sanded, glued etc with basic wood working stuff.
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 08-11-2025, 07:23 PM   #5
J Franklin
J Franklin's Avatar
Upholstery shops can supply it. I used waterproof masonite in my model A.
