Old 08-06-2025, 06:44 PM   #1
Alan O'Connell
Default 1936 gas tank sending unit float
Who makes the floats that slide over the arm where the original cork float was secured?
Alan O'Connell is offline   Reply With Quote
Old 08-06-2025, 07:17 PM   #2
Kube
Kube's Avatar
Default Re: 1936 gas tank sending unit float
Alan, I do not recall having ever seen a replacement cork float. I believe you'd be best served by using a brass float. If your arm won't accept the brass type, let me know and I can send you the arm for the brass float.
Easy enough to swap arms.
Old 08-06-2025, 10:02 PM   #3
petehoovie
petehoovie's Avatar
See > https://www.snydersantiqueauto.com/p...9370&cat=41706
GAUGE FLOAT ONLY
Part # A-9313-C | Model Year 28-31
Made from modern material that is resistant to today's ethanol in fuels. The last float you'll ever need to buy! Replace it once and forget about it.
Dimensions - 1 1/8" x 1 3/8" long
Also, see this thread > https://www.fordbarn.com/forum/showt...ght=cork+float
Old 08-07-2025, 07:01 AM   #4
Kube
Kube's Avatar
Wow! Thanks Pete!
Old 08-07-2025, 09:34 AM   #5
hotcoupe
hotcoupe's Avatar
I believe that material is "nitrophyl",I replaced the float in my '37 several years ago with it. Works great!
Tom
hotcoupe is offline   Reply With Quote
Old 08-07-2025, 10:47 AM   #6
Newc
Newc's Avatar
Keep in mind that the Model A folks have solved many problems we V8ers may encounter. Newc
Old 08-07-2025, 11:35 AM   #7
petehoovie
petehoovie's Avatar
Tom
Nitrophyl is a type of material used to make carburetor floats, known for being resistant to fuel and not absorbing gasoline, unlike traditional brass floats. It is often preferred for its durability and performance, especially in applications involving ethanol-blended fuels.
https://rogerscorp.com/Elastomer%20Components/NITROPHYL
Old 08-07-2025, 02:09 PM   #8
Alan O'Connell
Thanks Pete
