Old 07-27-2025, 01:01 PM   #1
oldford
Default Replacing a rear transmission mount, 32
I replaced the front engine rubber supports and would like to do the rear. Can a rear transmission mount support be replaced with out removing transmission on a 1932 coupe. Or pushing engine forward. thanks
oldford is offline   Reply With Quote
Old 07-27-2025, 01:27 PM   #2
Mart
Mart's Avatar
Default Re: Replacing a rear transmission mount, 32
No. Unless the rear trans mount is known to be faulty, it is best to leave it alone and then consider changing it when other work is being undertaken that requires engine and trans removal. It is not something to change just for fun. They are normally pretty robust.
Old 07-27-2025, 03:43 PM   #3
oldford
I did not think it could be done but thought I would ask. It's really not that bad of shape but I thought as long as I'm replacing the front supports I would do the rear, thanks
