My 31 has a Tollitson carb on it but slowly drips. I took it apart and reworked as best I could before installation as it had been rebuilt years ago and never used. Also my indented cowl gas shut off has a slow leak. It seemed to resist removal and I was afraid it might break. Is there a way to stop the Tollitson leak? If I buy a Zenith how can I be sure it wont leak? I had one in another car that leaked. Where is the best place to buy a Zenith? Ebay has them but really high priced. So far Ive had a 30 tudor sedan, a 30 Cabriolet, a 30 Coupe, a 30 pickup, another 30 coupe and now a 31 coupe. Only 2 leaked like this.
#2 | |
![]() Quote:
www.whidbeymodelaclub.com |
You can also check with Dave Renner here in Michigan. He might be able to help you with a replacement Zenith.
--------------------------------------- 1929 Model A Tudor - "Darla" '29 Model A: Old enough to start with a crank, young enough to steal the show! "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
If you have a crows foot of the proper size an extension to clear the firewall and 18 in breaker bar should work for removing the valve. I’ve used an under sink, plumbing wrench with a cheater bar. That valve is rebuildable ! the taper can be lapped for a leak less valve, before reinstalling clean the trough out in the tank outlet. You maybe can rebuild the valve without removing it.
If you can take the valve apart in situ then you can use EZ Turn to stop it from leaking, see link below. If you use the valve every time you use the car and drive your car frequently, then you have to add more EZ Turn every 6 months or so.
https://www.aircraftspruce.com/catal...?clickkey=5414
Bert's Model A Centre selection of Carburettors |
erased ... off topic
Hello Bart, you must fix the shut off valve on the firewall. The EZ Turn suggestion looks good to me. The shut off valve was installed by Ford to provide a positive shutoff in the event of a leak downstream. I use mine on every shut down especially in public areas. A fellow club member went to the supermarket, had a leak in the parking lot, the police were called, an emergency was declared, the area was closed off and evacuated and the car was towed away and impounded. It was a mess. Not a big deal for a Model A owner but to the public and the police it was a disaster in the making! That valve has to be tight. The valve in the carburetor is prone to leakage because of dirt and rust in the gas tank. Ed
I have a huge advantage. I have a Weber downdraft carburetor that requires a fuel pump. The fuel pump will not pass any gasoline when off. It like having an automatic shut off valve. To keep the gasoline from forming a sludge in my carburetor, I still have to turn off the fuel valve under the tank and run the carburetor dry when I am going to be away for a month or more.
On your carburetor lightly dress the gasket surfaces with a flat bastard file until they clean up they can warp. Here is a new gasket set ,Mikes has rebuild kits too. You could get an electric shut off ,hooks to your non pop out ignition switch. .https://www.mikes-afordable.com/product/A9502T.html....https://www.mikes-afordable.com/product/A9189.html
It's not the destination ,it's the journey . Last edited by stevemclark; 07-16-2025 at 07:50 PM. |
