Old 06-26-2025, 12:23 PM   #1
Ed in Maine
Default 1931 Cabriolet 68C Door Parts
I am trying to find the correct part numbers and sources for the Striker Plates and the Door Handle Rubber Pads. There are so many choices but not sure what is correct.
Also, any suggestions on how to mount the striker plates on the door jam. There is no adjustment that can be made, so the holes in the jam must be made correctly. How are the correct locations for the screw holes determined? Thanks for your help.
One last question, did the 68C have a rubber door seal mounted between the door panel and the metal of the door? Thank you for your help. Ed
