Any tips on replacing the lower radiator hoses? The engine and radiator are out of the car at present time. Thanks in advance for any suggestions.
Yes, you might want to try making your own hose using copper pipe. These have been on for the last 30 years. You don't need to chrome plate them. I use 4 clamps per hose at water pump connection. Straight hose bought at NAPA. It's a higher quality hose than regular radisaor hose.
Does this mean premolded hoses aren't available? (Total newbie here.)
No. Not sure what this is about, hoses have been pretty easy to get.
Lower hoses are readily available. My idea is just an option if you want longevity and very durable hoses. Here's some replacements.
https://www.bing.com/search?q=8ba+lo...ANAB01&PC=HCTS |
Thanks for all the replies. I already have the hoses and clamps. Just wondered if there was any advantage to installing them in any particular order (engine first or radiator). There is not a lot of room to work down there.
But there is enough room to work down there. I like the hearing about that silglide. I just use Vaseline, it never seems to hurt the hoses.
I installed new lowers on the 52 Merc a few years ago. Either Napa or Rock Auto had them. I can't remember which. It was not a bad job to install.
https://www.youtube.com/user/roosty6/videos |
