Old 06-07-2021, 03:05 PM   #1
Ulysses6
Default cowl band
looking for a cowl band, for a january 30 155-D briggs town sedan.
anyone have, or making them new ?
Ulysses6 is offline   Reply With Quote
Old 06-07-2021, 03:53 PM   #2
JayJay
Default Re: cowl band
Some of the suppliers have them new.
https://www.brattons.com/cowl-band.html
If you want a used one suggest that you put a request up in the Swap Meet.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-07-2021, 03:58 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Reproduction cowl bands do NOT fit worth a flip. If you are going to use one, you must do the fit-work prior to painting. Because of this, we are restoring original cowl bands which is very laborious however much faster in time than fitting a new repro band.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-08-2021, 09:54 AM   #4
jak
the new repro bands are currently off the market. There were two companies making these in the past. One went bankrupt about 1 1/2 years ago, and the other is retooling to make a nicer and better fitting product. The company retooling is not giving any idea when they will be back on the market.
jak is offline   Reply With Quote
Old 06-08-2021, 01:48 PM   #5
Oldbluoval
Oldbluoval's Avatar
Is the Briggs a different length? I know many are the same and a few are about 1/2” longer per side. I have restored regulars..... restored by Doug Bruce (the best)
[email protected]
Old 06-08-2021, 03:27 PM   #6
BRENT in 10-uh-C
[email protected]
Bill, Clark needs the early 30 with the extra length. I suggested he check with Steve Becker.
Yes, Doug was the master, ...and unfortunately, all his knowledge left this earth when he passed.
BRENT in 10-uh-C
Old 06-08-2021, 04:04 PM   #7
Oldbluoval
Oldbluoval's Avatar
Thought that could be the case
Can’t help on that one
Old 06-08-2021, 08:26 PM   #8
David R.
I need an old rusty one for my AA
David R. is offline   Reply With Quote
Old 05-02-2025, 04:15 PM   #9
AHOOGA A & T
AHOOGA A & T's Avatar
Guys,
It has been a few years since I got on here and a lot has happened since then.
Starting with I have had some serious health issues. I got COVID really bad with large blood clots in my lungs, clots in my arms and legs and a really bad one that I thank God for saving me, a pulmonary saddle embolism that my Dr. said normally the next step would be the morgue. I also have a wound in my leg that started out as an infection and wound care has been treating since Nov. 2020. I have had surgery to close it, hyperbaric treatments which caused cataracts and I had to have surgery on it as well along with I am currently on my 6th PICC line for infections on it.
With all that I am still kicking and working on getting the shop up and running but on a more limited basis.
One of the first parts I should have on the shelf will be the Polished Stainless Cowl Bands. I will also have them in non polished if you want to do it yourself and plain steel.
I will also have most of the die stamped steel patch panels available along the Ford script ignition coils and with the bed wood for the Model T and Model A's.
I will let you all know when I have my inventory again and would appreciate it very much if you would still consider AHOOGA A & T for your patch panels and other parts.
Thank you all,
Dale Adkins
AHOOGA A & T
AHOOGA A & T is offline   Reply With Quote
Old 05-03-2025, 08:24 AM   #10
Tom F OHIO
Tom F OHIO's Avatar
It's been years since I mess with a cowl band. I have a chance to take a nice one off a 30 coupe and can't remember how to take it off without messing it up.
Any advice would be appreciated.
Tom F OHIO is offline   Reply With Quote
Old 05-04-2025, 03:10 PM   #11
gdmn852
gdmn852's Avatar
Hello I remember the repro cowl band a friend of mine tried fitting, gave up on it and bought a repaired original . It was too short and didn’t fit around the curve of the gas tank .
gdmn852 is offline   Reply With Quote
Old 05-04-2025, 08:47 PM   #12
JayJay
Tom - I presume the cowl band on a coupe attaches the same way as a sedan. One nut each side that goes to a stud that protrudes down from the cowl band at an angle through the bottom of the cowl assembly. You get to it with a socket. You then just tease the band off.
JayJay
Old 05-05-2025, 08:28 AM   #13
Tom F OHIO
Tom F OHIO's Avatar
Thanks Jay Jay
Old 05-05-2025, 08:54 AM   #14
Bob from Northport
Bob from Northport's Avatar
I have one in my shop off of a 1930 Coupe. It does NOT have the clips at the bottom that secure it to the body. It's a nice original but not perfect
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 05-07-2025, 09:07 AM   #15
larrys40
I have several bundles , I’ll check to see if I habe any of the long ones …
Larry
larrys40 is offline   Reply With Quote
